jackpoint rust repaired!, buying this car |
BK911 |
Sep 21 2015, 12:08 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
On wow. Not the way I am doing mine!
IMO the jack plate is superficial, unless you use it. Its the rocker behind that probably needs attention. Looks sorta like lipstick on a pig. |
Mike1981 |
Sep 21 2015, 01:03 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
On wow. Not the way I am doing mine! IMO the jack plate is superficial, unless you use it. Its the rocker behind that probably needs attention. Looks sorta like lipstick on a pig. I see your point He did cut out the rusted area The backside looked pretty good with no rust through My plan is to use Eastwood green stuff internally for the entire rocker then eastwood rust encapsulator on all exterior surfaces |
Lo-Fi Version | Time is now: 27th May 2024 - 07:26 AM |
