jackpoint rust repaired!, buying this car |
BK911 |
Sep 21 2015, 12:08 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
On wow. Not the way I am doing mine!
IMO the jack plate is superficial, unless you use it. Its the rocker behind that probably needs attention. Looks sorta like lipstick on a pig. |
Mike1981 |
Sep 21 2015, 01:03 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
On wow. Not the way I am doing mine! IMO the jack plate is superficial, unless you use it. Its the rocker behind that probably needs attention. Looks sorta like lipstick on a pig. I see your point He did cut out the rusted area The backside looked pretty good with no rust through My plan is to use Eastwood green stuff internally for the entire rocker then eastwood rust encapsulator on all exterior surfaces |
malcolm2 |
Sep 21 2015, 01:14 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I learned or should I say that I surmised, during my repair that the hole in the jack support is there to drain water. But what it does is let dirt and water in. Once the dirt is in and packed, the water is absorbed and starts the rust process from the inside.
So it should be on the maintenance list to take a punch and break up the dirt in the jack support once a year. You have either eliminated the access point for the dirt and water, or eliminated a way to get it out by welding a solid plate. And maybe should drill a hole in your new plate and force the "rust mort" in there. Cause the rust was on the long side too. I did a similar repair, but left the hole and used a similar product to rust mort. An inner channel spray paint from Eastwood on the inside. (EDIT) I just realized that in your photo, you can barely see the hole I mentioned. It is on the bottom left of the "pyramid". This photo may be an item that will work on either side. Hole on the top too. |
Mike1981 |
Sep 21 2015, 01:27 PM
I learned or should I say that I surmised, during my repair that the hole in the jack support is there to drain water. But what it does is let dirt and water in. Once the dirt is in and packed, the water is absorbed and starts the rust process from the inside. So it should be on the maintenance list to take a punch and break up the dirt in the jack support once a year. You have either eliminated the access point for the dirt and water, or eliminated a way to get it out by welding a solid plate. And maybe should drill a hole in your new plate and force the "rust mort" in there. Cause the rust was on the long side too. I did a similar repair, but left the hole and used a similar product to rust mort. An inner channel spray paint from Eastman on the inside. (EDIT) I just realized that in your photo, you can barely see the hole I mentioned. It is on the bottom left of the "pyramid". This photo may be an item that will work on either side. Hole on the top too. Hello MAlcom2 I did leave out a few pictures That is probably why some folks are making negative statements Sequence of repair: 1 Grind off all rust 2 Treat inner and outer pyramid with rust stop 3 cut out rust 4 weld new plate in 5 cover with undercoating This was the exact procedure I was going to follow. The only additional steps I see: 1 Fog inside main long and inner long with Eastwood green rust stop 2 Spray Eastwood Rust arrestor on bottom of longs and a few sections under the car I do not see the issue here Thanks for the constructive responses Mike |
draganc |
Sep 21 2015, 03:25 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Congratulations!! You will have lots of fun with the car.....keep us posted.
Chris H. |
Sep 21 2015, 04:14 PM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Do we get to see the rest of it or no (IMG:style_emoticons/default/biggrin.gif) ?
Mike1981 |
Oct 7 2015, 07:12 PM
arsprod |
Oct 10 2015, 07:48 PM
Member Group: Members Posts: 199 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
Nice! Has less rust in the jack ports than mine and I'm guessing less than it's gonna have living in Detroit! Enjoy!
Lo-Fi Version | Time is now: 26th April 2024 - 07:06 AM |
