Headlight doesn't go up, but it goes down |
era vulgaris |
Sep 20 2015, 07:20 AM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Out driving last night, and my driver's side headlight wouldn't go up when I pulled the headlight switch so I had to manually crank it up with the thumbwheel on the back of the headlight motor. But to my surprise, it went back down by itself when I turned the headlights off.
Is this an issue with the relay, the motor, or something else? I rarely drive at night, but prior to this the headlight on that side used to wink (go up and down twice) when I turned the headlights on. Not sure if that was a related issue. |
Sep 20 2015, 07:36 AM
914-6 GT in waiting Group: Members Posts: 19,257 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The motor only spins in one direction so if it goes down, the motor is good.
era vulgaris |
Sep 20 2015, 07:53 AM
That's good to know! I'm guessing maybe an issue with the relay then. Someone once told me that the winking was due to a bad relay, but I thought it gave the car character so I never did anything about. Maybe it finally failed. I'll put it on the test bench and see if it activates or not.
BeatNavy |
Sep 20 2015, 08:03 AM
That's good to know! I'm guessing maybe an issue with the relay then. Someone once told me that the winking was due to a bad relay, but I thought it gave the car character so I never did anything about. Maybe it finally failed. I'll put it on the test bench and see if it activates or not. Mine does the same thing (winks) and I also like the character it adds (which I find amusing). A complete failure is less amusing, however. Let us know what you find. |
Sep 20 2015, 05:03 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The relay powers the motor; if the motor spins then the relay is likely good.
The headlight switch might have a problem, or the wiring from the switch to the headlight motor assemblies. Or maybe even one of the microswitches inside the assembly which say that the light is up or down. --DD |
bandjoey |
Sep 21 2015, 10:05 AM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
My Winking was cured with all the grounds being cleaned. Never hurts to try. Might be why they didn't go up. I took off the wires and it was gray under there, not bright metal
Hope that helps |
sfrenck |
Sep 21 2015, 10:35 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
I had problems like that - turned out my wiring was melted thru in various spots between the fuses and the headlight motors.
Replacing the wiring fixed it. |
Sep 21 2015, 10:54 AM
era vulgaris |
Sep 21 2015, 12:18 PM
So I cleaned the grounds at the headlight. Nothing.
Then I cleaned the three contacts in the multi-pin plug. Bingo! (IMG:style_emoticons/default/piratenanner.gif) EZ PZ fix. Headlight works perfectly, although sadly it no longer winks. But I'm very glad I didn't have to replace any parts! |
Sep 21 2015, 02:07 PM
my old car used to wink. I liked it. Maybe we could developed a mod to do it if we want.
era vulgaris |
Sep 21 2015, 03:41 PM
The easiest way would be to splice in an additional spst switch into the wire that goes from the relay coil to ground. Then you could control the winking, and do it anytime you wanted to without the headlight turning off.
Add a switch for each side, and then you could control both of them independently. |
sfrenck |
Sep 22 2015, 06:02 AM
I had problems like that - turned out my wiring was melted thru in various spots between the fuses and the headlight motors. Replacing the wiring fixed it. Scott - I think I had similar issue when mice got a wire or 2. Right? Right - just where the wires went through the firewall they were melted / eaten and were intermittently touching other things. |
EdwardBlume |
Sep 22 2015, 06:36 AM
So I cleaned the grounds at the headlight. Nothing. Then I cleaned the three contacts in the multi-pin plug. Bingo! (IMG:style_emoticons/default/piratenanner.gif) EZ PZ fix. Headlight works perfectly, although sadly it no longer winks. But I'm very glad I didn't have to replace any parts! I love happy endings! (IMG:style_emoticons/default/cheer.gif) |
Lo-Fi Version | Time is now: 8th May 2024 - 05:05 PM |
