era vulgaris
Sep 20 2015, 07:20 AM
Out driving last night, and my driver's side headlight wouldn't go up when I pulled the headlight switch so I had to manually crank it up with the thumbwheel on the back of the headlight motor. But to my surprise, it went back down by itself when I turned the headlights off.
Is this an issue with the relay, the motor, or something else?
I rarely drive at night, but prior to this the headlight on that side used to wink (go up and down twice) when I turned the headlights on. Not sure if that was a related issue.
Sep 20 2015, 07:36 AM
The motor only spins in one direction so if it goes down, the motor is good.
era vulgaris
Sep 20 2015, 07:53 AM
That's good to know! I'm guessing maybe an issue with the relay then. Someone once told me that the winking was due to a bad relay, but I thought it gave the car character so I never did anything about. Maybe it finally failed. I'll put it on the test bench and see if it activates or not.
BeatNavy
Sep 20 2015, 08:03 AM
QUOTE(era vulgaris @ Sep 20 2015, 09:53 AM)
Mine does the same thing (winks) and I also like the character it adds (which I find amusing). A complete failure is less amusing, however. Let us know what you find.
Dave_Darling
Sep 20 2015, 05:03 PM
The relay powers the motor; if the motor spins then the relay is likely good.
The headlight switch might have a problem, or the wiring from the switch to the headlight motor assemblies. Or maybe even one of the microswitches inside the assembly which say that the light is up or down.
--DD
bandjoey
Sep 21 2015, 10:05 AM
My Winking was cured with all the grounds being cleaned. Never hurts to try. Might be why they didn't go up. I took off the wires and it was gray under there, not bright metal
Hope that helps
sfrenck
Sep 21 2015, 10:35 AM
I had problems like that - turned out my wiring was melted thru in various spots between the fuses and the headlight motors.
Replacing the wiring fixed it.
Sep 21 2015, 10:54 AM
QUOTE(sfrenck @ Sep 21 2015, 12:35 PM)
Scott - I think I had similar issue when mice got a wire or 2. Right?
era vulgaris
Sep 21 2015, 12:18 PM
So I cleaned the grounds at the headlight. Nothing.
Then I cleaned the three contacts in the multi-pin plug. Bingo!
EZ PZ fix. Headlight works perfectly, although sadly it no longer winks. But I'm very glad I didn't have to replace any parts!
Sep 21 2015, 02:07 PM
my old car used to wink. I liked it. Maybe we could developed a mod to do it if we want.
era vulgaris
Sep 21 2015, 03:41 PM
The easiest way would be to splice in an additional spst switch into the wire that goes from the relay coil to ground. Then you could control the winking, and do it anytime you wanted to without the headlight turning off.
Add a switch for each side, and then you could control both of them independently.
sfrenck
Sep 22 2015, 06:02 AM
QUOTE(mepstein @ Sep 21 2015, 12:54 PM)
Right - just where the wires went through the firewall they were melted / eaten and were intermittently touching other things.
EdwardBlume
Sep 22 2015, 06:36 AM
QUOTE(era vulgaris @ Sep 21 2015, 11:18 AM)
I love happy endings!
