power antenna or not |
arsprod |
Sep 20 2015, 04:17 PM
Member Group: Members Posts: 199 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
I just replaced mt radio and antenna. I had a power antenna from another car that fits fine and looks nice. However, I'm a little concerned about the antenna unit sitting in the open wheel well. Anyone have any experience with a power antenna on their 914?
GeorgeRud |
Sep 20 2015, 04:20 PM
The one in my 911 is in an open wheel well since 1984 and seems to work fine.
Cairo94507 |
Sep 20 2015, 04:55 PM
Michael Group: Members Posts: 9,770 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
My last two Sixes had power antennas in the wheel well and no issues at all - ever. I just bought one for my '71 and will wire it so it has an on/off switch so when I am streaming music I can leave the antenna down. Otherwise it draws power from the radio and when you turn the radio on the mast goes up.
TheCabinetmaker |
Sep 20 2015, 05:02 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
3 years on mine. No problems. If your concerned, just cut a piece of plastic to go in front of it to protect it from flying wheel debris.
arsprod |
Sep 20 2015, 05:05 PM
Ok gents I'm convinced and will wire it up! Good idea about the switch Cairo. Thanks
Cairo94507 |
Sep 20 2015, 06:42 PM
You are welcome sir. I like the idea about some sort of a shield to protect the antenna from flying debris.
Scotty? I was thinking something that would secure to the antenna electric motor and protect it. I do not want to drill any holes in the body. Or, I guess Scotty could weld a couple small tabs in the wheel well for a shield to secure to. |
arsprod |
Sep 20 2015, 06:48 PM
You are welcome sir. I like the idea about some sort of a shield to protect the antenna from flying debris. Scotty? I was thinking something that would secure to the antenna electric motor and protect it. I do not want to drill any holes in the body. Or, I guess Scotty could weld a couple small tabs in the wheel well for a shield to secure to. I was thinking a zip lock bag! If George has driven his 911 in Chicago with the motor assembly unprotected since 1984 I think I'll be ok. |
Lo-Fi Version | Time is now: 20th May 2024 - 05:58 AM |
