OT maybe, VW |
OT maybe, VW |
oldschool |
Sep 20 2015, 06:07 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
My buddy ask if a type 4 can be put in his 1971 bug? any links would be cool.
oldschool |
Steve |
Sep 20 2015, 06:11 PM
914 Guru Group: Members Posts: 5,580 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Tom_T |
Sep 20 2015, 06:28 PM
I've seen them in Ghias with some tin/engine bay wall mods, usually using the late Bay Window Bus T-4 motor since it's already set-up to fit the van as a taildragger.
So I would think that you could work a Bus T-4 into a Bug as well, but not sure how much work. You can check with Ron at FAT Performance in Orange, as he's build as many T-4s as anyone - race, off-road & street, including many Baja 500/1000 winners over the years. IIRC a certain T-4 engine builder back east in GA learned the trade from Ron or one of his sub-contractors out here in SoCal. http://fatperformance.com/home/ (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Sep 20 2015, 06:30 PM
Yes, it was a common swap.
Use an old type one round fan cover Use two sets of type four head tin, sectioned to make up two head tins that basically use the back half of our 914 tin on both ends, so all the air comes from the round fan. Type4 secrets and shoptalk forums has some threads on how to build it....not terribly hard to do. Cip1 and a German firm have the unique generator stand that fits on op of the oil filler tower. Rich |
Sep 20 2015, 06:34 PM
Tell your friend to lookup "German look" beetles
It's European origins but basically is a type 4 motor into a beetle as the common mod. |
bandjoey |
Sep 20 2015, 06:40 PM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
the samba.com. Lots of the
Mark Henry |
Sep 20 2015, 10:20 PM
Read my signature....the bit about the '67 bug
DBCooper |
Sep 21 2015, 05:31 AM
Yeah, big block bug. If anyone's interested I have one of Joe Locicero's original (pre-Raby) DTM fan shrouds left over. Converts the T4 cooling to upright so it fits in a T1 and even still has Joe's own handwritten assembly notes.
Mark Henry |
Sep 21 2015, 11:15 AM
The fastest T4 conversion is a DTM fan shroud with the surround kit, a type 4 200mm conversion flywheel, beetle clutch (KEP stage 1 PP) and a pair of weber IDF carbs.
Joe Locicero shroud is ok, but will take you a fair bit of fab work. A long time ago I worked on a bug with a T4 fan what a total POS install, ended up changing it to a Sharpbuilt (911 fan). One cool thing I did was when replacing the rear apron was I left it unwelded so the apron could be removed when R&Ring the engine. What I did is a all metal cross between a VW, Joe Locicero and DTM shroud Turned out nice, but I'd never do again just because of the time it took to build. Mine is also a bit of a tighter fit because I used a 911-901 transmission. Here's a pic, bit dirty because it's my summer daily driver. Attached image(s) |
Jake Raby |
Sep 21 2015, 11:43 AM
2270 Roller Cam with A/C and V2 DTM
EdwardBlume |
Sep 21 2015, 11:44 AM
The real deal old time 356 racers used TIV motors....
Lo-Fi Version | Time is now: 8th May 2024 - 03:33 PM |
