need suggestions, cant get it off |
grasshopper |
Mar 5 2005, 04:17 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
i cant seem to get the shifter bar to come loose. I removed the screw(where the arrow is) and i lightly tapped it with a mallet but i wont break loose. What should i do?
Attached image(s) |
jwalters |
Mar 5 2005, 04:20 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Put a vice grip on very low tension upstream of the shift tube--only enough to grab it gently and not cave it in or mar it up too much--then rotate it from side to side in very small increments while putting tension on it towards the firewall--and it will come out-
That siezure is just from years of being mated up--- |
Rusty |
Mar 5 2005, 04:21 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Get someone to sit in the passenger compartment. Have them put the shifter in 2/4 gear, and hold it.
Sometimes all you need is to keep pressure on the shift rod in the opposite direciton. Then take a mallet and tap the fitting loose. -Rusty (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) |
mightyohm |
Mar 5 2005, 04:41 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Some liquid wrench won't hurt.
grasshopper |
Mar 5 2005, 04:45 PM
thanks for the advice! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Lo-Fi Version | Time is now: 31st May 2024 - 11:28 AM |
