WTB 1973 1.7L Timing chain cap / cover thing |
FlippinEh |
Sep 22 2015, 09:37 AM
Newbie Group: Members Posts: 19 Joined: 14-September 15 From: Alberta Canada Member No.: 19,158 Region Association: Canada |
Missing the cap in the pic. Need shipped to Aberta Canada please.
TheCabinetmaker |
Sep 22 2015, 10:01 AM
I have some. Shipping will cost more than the part
TheCabinetmaker |
Sep 22 2015, 10:04 AM
First class mail would be about 9.00 usd. You can pay me what ever the part is worth to you.
sean_v8_914 |
Sep 22 2015, 11:12 AM
try flat rate box or envelope $5.
euro911 |
Sep 22 2015, 11:14 AM
Wow, is it that much for a small padded envelope? ... (IMG:style_emoticons/default/blink.gif)
I screwed in a PVC pipe nipple with a cap on it until I finally got the correct cap from a parts car. |
GaroldShaffer |
Sep 22 2015, 11:29 AM
TheCabinetmaker |
Sep 22 2015, 02:18 PM
Small flat rate box is not $5.00. It's almost $30.00. I don't normally price any shipping without knowing what I'm talking about (IMG:style_emoticons/default/wavey.gif)
forrestkhaag |
Sep 22 2015, 03:09 PM
Well...... Since you have immersed yourself into this usually rough crowd.... Timing Chain??? 1.7?
The technical term is Fan Shroud Screw-top Peekaboo Hole Insert.... or FSSPHI for short. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/beerchug.gif) |
FlippinEh |
Sep 22 2015, 03:11 PM
FlippinEh |
Sep 22 2015, 03:13 PM
Well...... Since you have immersed yourself into this usually rough crowd.... Timing Chain??? 1.7? The technical term is Fan Shroud Screw-top Peekaboo Hole Insert.... or FSSPHI for short. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/beerchug.gif) Someone told me it was the timing belt or chain cover. I'm a 914 noob lol. I don't have the thingamajig so That's what I thought it was (IMG:style_emoticons/default/smile.gif) |
euro911 |
Sep 22 2015, 03:45 PM
It's more of an inspection port for checking/adjusting the ignition timing settings. You can run without a cap, but it does release some cooling air that should be going somewhere else. Heck, you can even stuff a tapered rubber stopper (like a cork) in the hole until you gain access to the correct part (IMG:style_emoticons/default/idea.gif)
Maybe someone else up in Canuckland has a spare, or can set up a group buy for a quantity and split the high shipping cost, amongst the needing recipients - just a thought (IMG:style_emoticons/default/confused24.gif) |
TheCabinetmaker |
Sep 22 2015, 06:41 PM
Flippin, your part is boxed. Will go out tomorrow. Gonna send you a couple of valve cover gaskets too.
Curt |
Lo-Fi Version | Time is now: 11th May 2024 - 09:54 AM |
