BUILD-OFF CHALLENGE: Rightpedals 74, 914 challenge build |
rightpedal |
Sep 27 2015, 07:45 AM
rightpeda; Group: Members Posts: 60 Joined: 6-September 15 From: annapolis Member No.: 19,133 Region Association: MidAtlantic Region |
rightpedal |
Jun 12 2016, 07:56 PM
A looooooog over due update.
I bought a radiator fan combo A Subaru 3.0, 5mt trans, computer, starter, harness, and mounts(Crazy Rays pickurpart) clutch slave (luk from rockauto) honda clutch master (luk rockuto) clutch kit from ebay chunk of 1/4 aluminum Started cleaning up the floor and adding the tunnel for the cooling tubes. I used an old shelving unit for the sheet metal. My thinking is a 1 1/2 deep tray sits just under the factory consul hump. Since I'm not using the factory shifter, wiring harness or fuel lines I might as well take up space with two 1 1/2 tubes. I don't like to use soft lines if i can help it. The plan is to run hard lines under the car with soft connections front and rear. the Subie 3.0 is from a 2002 outback that was completely caved in on the driver side. No Idea of the millage but everything in the engine compartment pointed to a running engine that had been well maintained. The glitch was I went back two days later to pull the harness and computer. The car was already crushed. A couple weeks later another 3.0 showed up at a different crazy rays. I love pick ur parts. The 5mt trans was pulled from a 2002 Impreza that had a pretty hard front impact. This is more of a gamble. The drive pulleys were mangled and it cracked the alt/ac mount. the trans appears to have escaped the the bulk of the impact. |
Lo-Fi Version | Time is now: 15th May 2024 - 03:41 PM |
