BUILD-OFF CHALLENGE: Rightpedals 74, 914 challenge build |
rightpedal |
Sep 27 2015, 07:45 AM
rightpeda; Group: Members Posts: 60 Joined: 6-September 15 From: annapolis Member No.: 19,133 Region Association: MidAtlantic Region |
76-914 |
Jun 13 2016, 08:25 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Wow! You stole that drive train. (IMG:style_emoticons/default/piratenanner.gif) Your going to love that 3.0. Smooth as a sewing machine and nice torque curve, 25mpg! Two things; did you get the ECU for that motor (IIRC, 2001-02 are the same; 2003 is different) and did you clean that oil cooler? I couldn't see it in the pics after you cleaned the motor. (IMG:style_emoticons/default/beerchug.gif)
rightpedal |
Jun 13 2016, 05:00 PM
Wow! You stole that drive train. (IMG:style_emoticons/default/piratenanner.gif) Your going to love that 3.0. Smooth as a sewing machine and nice torque curve, 25mpg! Two things; did you get the ECU for that motor (IIRC, 2001-02 are the same; 2003 is different) and did you clean that oil cooler? I couldn't see it in the pics after you cleaned the motor. (IMG:style_emoticons/default/beerchug.gif) Yea I'm pretty much steeling your entire build idea. Its the perfect combo. I am not running AC but I can always retro it in. Both cars were 2002s and I grabed the intake + extra sensors out of the wiring harness/computer car. I pressure washed the motor just so mock up wasn't as greasy. I have to build the cradle, measure for axles, figure the firewall exit for the coolant lines, figure fuel feed, heater hose feed, and wiring/computer. Then the engine comes out and the bay gets cleaned up. I was toying with just replacing the cooler over cleaning but thats on the list after mock up. Steve |
Lo-Fi Version | Time is now: 14th May 2024 - 10:36 PM |
