BUILD-OFF CHALLENGE: Rightpedals 74, 914 challenge build |
rightpedal |
Sep 27 2015, 07:45 AM
rightpeda; Group: Members Posts: 60 Joined: 6-September 15 From: annapolis Member No.: 19,133 Region Association: MidAtlantic Region |
Andyrew |
Jun 13 2016, 11:11 AM
I also love the center tunnel mod!
Be sure you use SS tubes. I contemplated welding in stainless steel tubes in my setup. May still do that. Ifin you do do that I would suggest that you add another layer of steel between the cabin and the tubes and put some insulation in there or at least some kind of heat barrier. If the tubes are held off the steel 1/2" then the radiant heat should be much better. |
rightpedal |
Jun 13 2016, 05:06 PM
I also love the center tunnel mod! Be sure you use SS tubes. I contemplated welding in stainless steel tubes in my setup. May still do that. Ifin you do do that I would suggest that you add another layer of steel between the cabin and the tubes and put some insulation in there or at least some kind of heat barrier. If the tubes are held off the steel 1/2" then the radiant heat should be much better. Thanks The tunnel made sense to me. You and I are on the same page. Im going back and forth on Insulation sleeve vs enough air gap. If the lines hang down a little it wont bother me. I figure keep the strapping semi flexible and some air gap/shock in case i do bump the bottom of the car. |
Lo-Fi Version | Time is now: 15th May 2024 - 05:27 PM |
