Headlight Position, Headlight |
dralf |
Mar 6 2005, 07:19 AM
Member Group: Members Posts: 230 Joined: 24-January 04 From: Dayton, Oh Member No.: 1,597 |
The problem with getting old is that my memory works just well enough to remember that I read something about a subject, but not where I read it !
My headlights in the down position appear to be below the lines of the front trunk lid. They are retracting about an inch too low. I recall as I mentioned a simple fix for this by disconecting power or something and readjusting something, but I have searched for the tech article to no avail. Does someone out there have a better memory than I do, regarding that easy fix ? OR some suggestions ? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
davep |
Mar 6 2005, 07:31 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Isn't that what the adjuster screw is for?
dralf |
Mar 6 2005, 08:12 AM
As soon as I finish my coffee I will go out and take a look but I was unred the impression that that adjuster fixes the up position...but I have been wrong many time before.
Porsche Rescue |
Mar 6 2005, 10:55 AM
The bolt is for "up" stop I believe. I adjusted mine level with the hood by loosening the pivot bolts, some in the trunk and some accessed inside the wheel well. Last time I only had to use the ones in the trunk. In my case they were not closing enough.
Lo-Fi Version | Time is now: 29th May 2024 - 05:42 AM |
