BUILD-OFF CHALLENGE: Michigan Build, Garland, Never ending project, 8/2023 reinstalling headlamp housings |
Garland |
Sep 30 2015, 10:39 PM
Restoration Fanatic Group: Members Posts: 1,327 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
The start: 2016 Build-Off Here I go! I purchased the car on eBay in 1999 site unseen, and only two polorid's in the post. Looked great, sitting in a empty dusty old garage. I ask lots of questions, original paint? Factory new looking wheels? History, on and on. He couldn't tell me anything about the car, his buddy owned it and he new nothing. Singed over ownership 6 mts ago. He did say looks like a great car, and knows it was fast. Says 2.0 on it. 400 miles away, a buddy with a flat bed, it was worth the risk. Price was right. On arrival, I'm on it, all over the car. Long story short the thrill is gone! Repaint in somebody's garage, 50 footer, or a polorid. Rear end hit, hard, car pushed into something damaged the left front. Right front damage, not to bad. Engine runs on 2 cylinders, yet it is a 2.0, with carbs. Must have been the reason for the FIRE in the engine bay. One head is trashed from the fire, and theirs nothing else to talk about, except the A/C system they must have got on eBay and hacked into the car. (Key words: eBay, "was" fast, Polorid, and risk) I swapped in a 1.7 and a tail shift 2.0 exchangers with triad exhaust. 1971 complete interior (had one). Plus just about every other trim part. Polished the paint, cleaned up the wheels, and I drove it. Now it's time to fix It. MICHIGAN BUILD (Short monthly update posts) @ Contest Link 1973 Red 1.7 5 Major Tasks to complete during the Challenge: 1. Replace back half of rear trunk floor. (Rusted, rear ended, poorly patched) & Replace entire rear body panel, and Bumper. (Rear ended, poorly repaired) & Patch in 1/2 left front fender. (Poorly repaired) 2. Delete headlamp doors, modify hood, and relocate headlamps. 3. Install 4 steel flares, and modify all valances. 5 lug, and wheel tire package. 4. Build up, and replace engine. Installed now: With: 1.7 914 Engine balanced 260 x 396 Cam .006 96mm Big Bore kit Mallory Unlite Distributor 14004 Weber 40 DCNF (w/ very short intakes) Air jet 1.80 Main 1.25 2.0 L exhaust Work in progress replacement. 5. Major interior renew. Still need to finish the engine, and start it. Purchased here from a member a few years ago. I have a 2nd 914 that I'm also working on, and been a owner of many since the 70's. I do all my own work. My enjoyment time. Attached image(s) |
Darren C |
Jul 23 2016, 01:16 PM
Member Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
I can't bear to look.......That wood bit could snag and break the lens real easy.
You might want to try a hole saw instead. Good luck. |
76-914 |
Jul 24 2016, 08:54 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I can't bear to look.......That wood bit could snag and break the lens real easy. You might want to try a hole saw instead. Good luck. Amen, but the pilot bit will want to pull into the plastic very quickly as it is a std bit. Plastic drill bits have a very acute angle (135 degree IIRC) which keeps it from pulling thru too quickly resulting in a broken plastic piece. So yes, a hole saw is best but pre-drill the pilot hole with a bit made for plastic or recess the pilot bit enough so that it doesn't bite into the material too early. Aircraft Spruce sells these bits if you can't find them locally. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 28th April 2024 - 09:13 PM |
