BUILD-OFF CHALLENGE: Madmax914, '74 914 Subaru Turbo Conversion |
madmax914 |
Oct 1 2015, 11:36 AM
Member Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
The car is a ’74 1.8L presently on jack stands with both front and rear suspensions removed. Motor and transaxle is removed with plans for a Subaru conversion. Driver side floor pan under the seat has rust which I plan on replacing and of course the battery tray is rusted pretty badly. This was an A/C car so the front trunk had been cutout which I have tacked in a replacement panel from Restoration and Design. The body itself has been blasted and a sealer coat of primer has been applied to protect the metal, by no means is ready for paint by my standards. The underside of the car is as it was from the factory 41 years ago. I have a little surface rust in the trunk area, which is remarkable considering it has spent most of its life in the Pacific Northwest.
My plans are to convert the drive train to a Subaru motor (turbo) & transmission. I will attempt to use the Outfront Motorsport header which relocates the turbo to the front of the motor. I also plan on fabricating a bulkhead type motor mount in the front to give me more room for the exhaust. I have already purchase all the parts for a 911 suspension including Bilstein coil over front struts. Wide body is a must and at this point I am really considering going wider that the GT fender widths. The car will sit as low as possible at a height that will allow it be driven on the streets. Many of the body panels will be replaced for fiberglass to lighten the car. All bodywork and paint(not my first rodeo but not an expert either), will be handled by myself since I’m too cheap to pay someone else to do it. As for the interiors it needs a complete overhaul and I’ll modify with Sparco/Recaro type seats and possibly do Auto Meter type gauges. I would like this car to meet the criteria most would think of when describing it as a true “Outlaw” car. BTW when you see my picture it will be clear why I call myself madmax914. Attached thumbnail(s) Attached image(s) |
914forme |
Oct 15 2015, 12:00 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Yes that is what I am liking about this design. And the fact that I can play around again a nd redo something I have done 3X times (IMG:style_emoticons/default/headbang.gif)
madmax914 |
Oct 15 2015, 12:12 PM
Yes that is what I am liking about this design. And the fact that I can play around again a nd redo something I have done 3X times (IMG:style_emoticons/default/headbang.gif) Before I started this, I over analyzed it quite a bit, measured, re-measured talked to other members and felt like it should work. So depending on how it all goes I have Jamie(Jrust) to credit or blame. (IMG:style_emoticons/default/lol-2.gif) |
JRust |
Oct 15 2015, 12:22 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Before I started this, I over analyzed it quite a bit, measured, re-measured talked to other members and felt like it should work. So depending on how it all goes I have Jamie(Jrust) to credit or blame. (IMG:style_emoticons/default/lol-2.gif) Yes my genius is commonly misunderstood as idiocy (IMG:style_emoticons/default/huh.gif) . How are you going to do exhaust from your Turbo? |
Lo-Fi Version | Time is now: 20th May 2024 - 06:52 PM |
