1.8 motor value question, part it out, make it run, just sell it |
rightpedal |
Oct 1 2015, 07:09 PM
rightpeda; Group: Members Posts: 60 Joined: 6-September 15 From: annapolis Member No.: 19,133 Region Association: MidAtlantic Region |
To finance my build I have to get rid of the spares. One that is taking up some real estate is the 1.8. I don't know much about the motor. It spins free and has housed a family of mice.
So the question is Where is its real value. Separate the tin, alternator, distributor, heads and sell the pieces? Sell the whole motor. It will take a bit of work to make it run. Is the cost/benefit worth it. Steve |
914Sixer |
Oct 1 2015, 08:45 PM
What I see is a 1.7 L engine. The crust on the throttle body and fan housing are indications of water corrosion. As long as the plugs where kept in the heads motor should be a core motor.
JeffBowlsby |
Oct 1 2015, 09:12 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
(IMG:style_emoticons/default/agree.gif) Its a 1.7L The 1.7L/1.8L engines are hard to sell for any amount of money. You will sit on it for awhile until you realize they are not worth anything then probably end of giving it away to anyone that will take it, maybe a high school autoshop for educational purposes. Essentially no significant value, even as parts
Mueller |
Oct 1 2015, 09:18 PM
I have 2 1.7 motors here at home....
One was free , parts or core motor for rebuild The rebuilt runner was $500 ( a few broken exhaust studs which brought the price down a little) |
Jesco Reient |
Oct 1 2015, 09:43 PM
Member Group: Members Posts: 135 Joined: 18-July 12 From: Western Washington Member No.: 14,690 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) Its a 1.7L The 1.7L/1.8L engines are hard to sell for any amount of money. You will sit on it for awhile until you realize they are not worth anything then probably end of giving it away to anyone that will take it, maybe a high school autoshop for educational purposes. Essentially no significant value, even as parts Except the earlier 1.7 Cases make a better build than a 2.0 case. The EA, Then W (Not WO) W cases should be checked for windage plate registers. Then the 2.0 GA, GB, GC. The metallurgy is a little nicer in the early cases, and they are thicker under the center area next to where the cylinders meet on the inside, so better support. |
rightpedal |
Oct 2 2015, 04:33 AM
Thanks all. I am a rookie at 914s...so all good info.
1.7 got it. What i'm getting from the posts is that there is near zero value in the motor. What about the tin, alternator, distributor, ect Steve |
barefoot |
Oct 2 2015, 06:47 AM
Senior Member Group: Members Posts: 1,274 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Do you have the whole FI system, or just what's in the photos ?
Some valuable parts there. |
Oct 2 2015, 06:52 AM
Near zero value but a good core to have for a full rebuild. If you have space to put it in a corner your good.
dlee6204 |
Oct 2 2015, 07:01 AM
Thanks all. I am a rookie at 914s...so all good info. 1.7 got it. What i'm getting from the posts is that there is near zero value in the motor. What about the tin, alternator, distributor, ect Steve IMO Maybe 30-40 for the distributor, throttle body 20, injectors 10, alternator doesn't really have value, 40-50 for the full set of tin if not rusted/cut. If the engine fan still has all of its blades it would be 100. Head about 40 as cores. Block doesn't really have a value. I could use those injectors if you want to sell. |
G e o r g e |
Oct 2 2015, 09:06 AM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
The rockers themselves are 100.
You should be able to move the whole thing easy at 200 with the rockers, let whomever wants the rockers part out the balance. Ymmv You can make more but it could take a while. |
stinkindiesel |
Oct 5 2015, 03:44 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I hate to think a 1.7 isn't worth anything. I'd love to have one for a spare, but shipping is prohibitive. Can't seem to find one nearby...
Gary |
bretth |
Oct 5 2015, 03:58 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I don't see how any 1.7 or 1.8 can be considered value less if it makes your car go compared to sitting and rotting away for years, sounds pretty valuable to me. Also remember how much more a running car sells for than one that doesn't. So unless you are sure the motor is toast it has plenty of value.
Brett |
Lo-Fi Version | Time is now: 18th May 2024 - 02:18 AM |
