| Mueller |
Oct 1 2015, 08:42 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Greeting Earthlings!
Got my 1st of many 914's back in '96 or so...'75 with a bad 1.8, installed new motor, drove it for a while and took apart...sold or cut it up, I don't remember...I've repeated that process about 4 times. Then finally in '07 I sold my last 914 along with my trailer and sold or gave away almost everything I had Porsche related except for a few small models and tee shirts. If you look at my member number, I have been around for a long time...I even have a "Smilie" (IMG:style_emoticons/default/MDB2.gif) At the beginning of '15 I mentioned to a co-worker I'd like another 914 and we made a deal for his in which I was able to make payments and I paid it off last week. ($200 a month for a grand total of $2000) The car: 1973 which originally had a 1.7 in it. The PO installed a 2.0 bus motor with megaquirt on it and drove it for a few years and parked it about 4 years ago due to no more compression in cylinder #3. I knew the car had some engine compartment rust in the hell hole, but it is worse that I thought it had, but I still think I got an okay deal on the car considering I was able to make payments and I knew the history of the car before I even considered buying it. 5x130mm redrilled /4 hubs with extra long studs up front with slide on spacer and bolt on 5x130 to 5x130 bolt on spacer in the back, not keen on either end. Plans: Install 1.8 motor I picked up from McMark after I fix a few broken exhaust studs (not Marks fault) Redo all suspension bushings and possibly the shocks (I think it has KYB's) Undecided on the wheels, now it has 16x7 53mm offset Phonedials with 205/50/16s. Fix hell hole. Fix up the interior. Do "something" with the turn signals front and back, I don't like 'em (IMG:style_emoticons/default/screwy.gif) Body needs some straightening and paint for sure. I might toss the green Porsche decal(s) for nothing at all or a different color. Below are pictures as the car sits across the street. Why across the street and not at my house? Well, I made a deal with the wife that my on going 6 year project car will be driving before I bring the 914 home, that will happen once I install the entire front suspension, install a wiring harness and finish building the engine and install that also. So possibly before the end of the year the 914 will be home! |
| Mueller |
Mar 4 2018, 01:25 PM
My car does not have a front swaybar, never had one.
So I bought a stock 15mm bar, didn't realize it had no hardware until I committed to buy it, still think it was a good deal. This thing looks brand new so I am not complaining. Spent a little time drawing up some parts for it while I wait for the garage to warm up this morning. The idea is to make a 15mm ID by 24mm OD split spacer, (green parts, hard to tell there are 2 pieces there) this will allow me to use an Igus MFM2430-30 bushing (dark colored part) to replace the factory rubber bushings. These are <$5 each (accounting for shipping, I bought 6 of them) ![]() |
Mueller Muellers Honda V6 914 project Oct 1 2015, 08:42 PM
Mueller Picture of me and my twins, I told them we'll ... Oct 1 2015, 08:45 PM
Jeff Bowlsby You know Mike, that's a lot of 914 for 2 bills... Oct 1 2015, 08:58 PM
Mueller To be honest with you, I couldn't have told yo... Oct 1 2015, 09:11 PM
shoguneagle Mike, I like the car you purchased and as Jeff say... Oct 1 2015, 10:53 PM
Krieger Looks like a great project! See if you can ge... Oct 1 2015, 11:40 PM
ConeDodger A build-off challenge might be just what you need ... Oct 1 2015, 11:46 PM
OllieG Hi Mike,
Did you ever own a white, later sprayed ... Oct 2 2015, 02:10 AM
A&P Mech Looks like a great starting point. I can't wai... Oct 2 2015, 05:57 AM
Olympic 1.7
Well, I made a deal with the wife that my on go... Oct 2 2015, 06:05 AM
tdgray I think I'm getting old (okay I know I am)...i... Oct 2 2015, 08:51 AM
Mueller
I think I'm getting old (okay I know I am)...... Oct 2 2015, 10:10 AM
OllieG
[quote name='tdgray' post='2246461' date='Oct 2 2... Oct 2 2015, 10:43 AM
Andyrew You gonna put roller bearings in the suspension? :... Oct 2 2015, 10:24 AM
RobW Let me know when you need a hand or a part. Love t... Oct 2 2015, 11:20 AM
RobW Shouldn't your daughters have cats in their ha... Oct 2 2015, 11:20 AM
madmax914 So Mike was the motor built by McMark? What intern... Oct 2 2015, 12:27 PM
Mueller
So Mike was the motor built by McMark? What inter... Oct 2 2015, 02:11 PM
914forme Say Grasshopper :wub: God luck Mike, and yes it n... Oct 2 2015, 02:18 PM
matthepcat I vote you do the custom drilled bolt pattern for ... Oct 2 2015, 02:27 PM
2mAn
I vote you do the custom drilled bolt pattern for... Jun 29 2016, 03:26 PM
Johny Blackstain Mike- I agree w/ the gang; go for the grasshopper ... Oct 2 2015, 02:53 PM
Mueller
Mike- I agree w/ the gang; go for the grasshopper... Oct 2 2015, 03:13 PM
Mueller Still in the hunting and gathering stages of the b... Oct 12 2015, 10:47 PM
Chris H. Dang that's almost junkyard cheap. You gonna ... Oct 12 2015, 11:12 PM
Andyrew Nice! Oct 12 2015, 11:24 PM
76-914 Which power plant you going with?? Oct 13 2015, 07:48 AM
Mueller
My 1.7 while... Oct 13 2015, 02:35 PM
76-914 Turbo that puppy. McMarks pulled pretty good. Oct 13 2015, 03:27 PM
Mueller
... Oct 13 2015, 10:58 PM
76-914
[quote name='76-914' post='2251444' date='Oc... Oct 14 2015, 09:38 AM
Andyrew
[quote name='76-914' post='2251444' date='Oc... Oct 14 2015, 09:42 AM
Mueller I found a drawing online that has the bolt hole lo... Oct 14 2015, 02:46 PM
Mueller No physical progress...just virtual progress :)
O... Oct 24 2015, 10:40 AM
Andyrew Ya... Thats awesome...
I would love to employ yo... Oct 24 2015, 01:28 PM
Mueller
I would love to employ y... Oct 25 2015, 01:10 PM
Andyrew
[quote name='Andyrew' post='2256394' date='Oct 24... Oct 25 2015, 02:41 PM
Mueller
[quote name='Andyrew' post='2256394' date='Oct 2... Oct 25 2015, 03:27 PM
trojanhorsepower I like the little computer, where did you get it? ... Oct 25 2015, 06:21 PM
Mueller Best Buy, I'd bet you can find them cheaper on... Oct 25 2015, 06:27 PM
trojanhorsepower Cool. Does it have mic and headphone/speaker port... Oct 25 2015, 06:34 PM
Mueller
Cool. Does it have mic and headphone/speaker por... Oct 25 2015, 07:50 PM
Andyrew
Cool. Does it have mic and headphone/speaker po... Oct 25 2015, 09:59 PM
mgp4591
[quote name='Mueller' post='2256814' date='Oct 25... Oct 25 2015, 10:30 PM
Andyrew
[quote name='Mueller' post='2256814' date='Oct 2... Oct 26 2015, 01:08 PM
madmax914 :confused: This computer conversation is making my... Oct 26 2015, 11:56 AM
Chris914n6 LA Dismantling had a booth at SEMA. Technically a ... Nov 4 2015, 10:50 PM
Mueller Update per request by Jeff....
Nada, nothing don... Dec 29 2015, 05:27 PM
Mueller My update for sake of doing an update....
0 progr... Jan 24 2016, 02:23 PM
r_towle Update? May 30 2016, 11:39 PM
Mueller
Update?
No real progress unfortunately, I did s... May 31 2016, 10:12 AM
r_towle I saw you talking about going to the August show s... May 31 2016, 12:19 PM
Mueller The car is still across the street, however I have... Jun 24 2016, 11:07 PM
A&P Mech Mueller, what machine control software are you usi... Jun 25 2016, 07:34 AM
76-914
Update?
No real progress unfortunately, I did ... Jun 25 2016, 08:05 AM
Mueller
Mueller, what machine control software are you us... Jun 25 2016, 11:11 AM
Mueller Started to work on the 1.7 engine....
4 out 8 exh... Jun 27 2016, 08:33 AM
Mueller I am glad to see that it looks like the missing ex... Jun 27 2016, 08:39 AM
Mueller Took heads and cylinders off tonight, didn't l... Jun 29 2016, 01:02 AM
G e o r g e
Took heads and cylinders off tonight, didn't ... Jun 29 2016, 08:55 AM
Marty Yeoman 93 bore x 71 stroke = 1929cc. Maybe that's wha... Jun 29 2016, 10:43 AM
Mueller
93 bore x 71 stroke = 1929cc. Maybe that's wh... Jun 29 2016, 02:22 PM
G e o r g e are the pistons dished or flat?
turning this into... Jun 29 2016, 03:19 PM
Mueller
turning this int... Jun 29 2016, 04:54 PM
Mueller July 1st update for Build-Off Challenge.
Took th... Jul 1 2016, 10:18 PM
Mueller Figured I'd throw some of my engine rebuild pi... Jul 5 2016, 09:32 PM
Mueller Got some goodies in the mail today.
Real 911 swi... Jul 5 2016, 09:33 PM
Andyrew Leakdown test yet? For some reason those valves do... Jul 5 2016, 11:05 PM
Mueller
Leakdown test yet? For some reason those valves d... Jul 5 2016, 11:10 PM
matthepcat Can't wait until you put a turbo on this motor... Jul 5 2016, 11:34 PM
Mueller Saved for future update.......... Jul 13 2016, 02:07 PM
2mAn Which MS setup are you using? Why are you trashing... Jul 13 2016, 02:41 PM
Mueller
Which MS setup are you using? Why are you trashin... Jul 13 2016, 03:19 PM
Andyrew Megasquirt would be perfect for a turbo motor :)
... Jul 13 2016, 04:14 PM
Mueller I failed miserably for the 1st Build-Off Challenge... Oct 18 2016, 08:59 AM
Mueller I finally have a 914 at my own house after almost ... Jan 21 2018, 08:11 PM
r_towle Slacker thread? Jan 21 2018, 08:30 PM
Krieger Nice! Good to see things movin! :beer2: Jan 21 2018, 08:44 PM
Mueller Pictures of ugly unknown brand headers. Jan 21 2018, 09:14 PM
tygaboy Mike - Great to see it's back home! Jan 22 2018, 08:48 AM
Mueller Drove up to Pet-a-llama and hung out with Chris (t... Jan 27 2018, 11:21 PM
tygaboy Mike - Always great to see you! I'll have ... Jan 28 2018, 08:40 AM
Mueller Thanks again Chris, much better pictures than view... Jan 28 2018, 10:37 AM
Mueller Drilled and tapped all the exhaust stud holes for ... Jan 28 2018, 11:33 PM
Mueller The picture of the tube being cut is for a homemad... Jan 28 2018, 11:44 PM
Mueller Started to gather parts to rebuild/restore my ugly... Feb 16 2018, 12:40 PM
Mueller Drew up my version of a hockey puck horn pad. Wait... Feb 25 2018, 09:48 PM
Mueller Removed gas tank today, the rubber hoses just snap... Feb 25 2018, 11:18 PM
Andyrew
Removed gas tank today, the rubber hoses just sna... Feb 26 2018, 08:13 PM
Mueller Finally test fit my new-to-me BBS wheels and measu... Feb 25 2018, 11:32 PM
mb911 Looking good.. Keep up the good work Feb 26 2018, 07:25 AM
Mueller All these hoses look original to me, I'd like ... Feb 26 2018, 05:35 PM
Chris H. Those wheels are PERFECT Mike. Love the long stud... Feb 26 2018, 08:17 PM
Mueller
Those wheels are PERFECT Mike. Love the long stu... Feb 26 2018, 11:15 PM
914forme More than likely rusty from a couple of items.
Sa... Feb 26 2018, 08:19 PM
Mueller
S... Feb 26 2018, 11:03 PM
Krieger I have not seen the plastic brake lines fail or cr... Feb 27 2018, 12:01 AM
Mueller Had car professionally steam cleaned down in San J... Mar 25 2018, 11:16 AM
Cairo94507 Hey Mike - I believe that is the same place where ... Mar 25 2018, 12:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th April 2026 - 11:35 AM |
