79 VW Bug fuel injection(NPC), Need Help with VW bug fuel injection |
BIGKAT_83 |
Oct 2 2015, 12:54 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
I've got a 25k mile 1979 VW Bug convertible. It starts up fine and runs for just a couple of seconds and then quits.
It does not matter if its hot or cold. Any ideas on where to start? Thanks in advance Bob |
hcdmueller |
Oct 2 2015, 01:49 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
Definitely L-jet. I retrofitted the same setup onto a Euro Baywindow bus I used to have. Your double relay might be bad or the wiring to the air flow sensor. You can check the fuel pump by pushing the air flow flap on the intake. If the key is on the pump should run. The pump only runs on the double relay while starting. Obviously check for vacuum leaks. The entire alternator stand is part of the intake. You may have some leaks there if the rubber parts of your intake are good.
Lo-Fi Version | Time is now: 17th May 2024 - 05:52 PM |
