| bd1308 |
Mar 6 2005, 07:31 PM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
first i need one of these.....i broke mine. It's the thing that you insert into the molex plugs to release the metal things.....
| bd1308 |
Mar 6 2005, 07:32 PM
okay....how do i get into the inside of this thing so i can clean everything off and re-grease everything....?
| bd1308 |
Mar 6 2005, 07:33 PM
do i need a special tool here?
| Dave_Darling |
Mar 6 2005, 07:43 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
You can fake up the pin-release tool (I thought the Molex-specific one was round?) by grinding down your smallest screwdriver. Or just pick up another pin release tool at Rat Shack (Radio Shack) or nearest equivalent electronics store.
You disassemble the distributor from the top, at least at first. You pull all of the external parts off (e.g., cap/rotor/points/vacuum dashpot), then you start working inside the distributor. The points plate comes out with some magic, or by unscrewing the tab that holds the ball bearing I think. I believe you can get in to some of the guts of the dizzy from there. For the rest, you drive out the pin that holds the drive dog onto the bottom of the shaft. Make sure you get the orientation of the dog & shaft clear so you can reassemble it correctly... Then I think you can slide the shaft out of the distributor body. I don't think that odd-shaped hole in your photo will do anything for disassembling the distributor. --DD |
| nebreitling |
Mar 6 2005, 07:45 PM
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
it's pretty easy, actually...
take it apart from the top, for the most part. mostly just screws and stuff. keep track of the orientation of everything -- it can be a minor PITA to figure it out later. if you're doing a full 'rebuild', you'll need some circlip pliers. check side to side action of the shaft to see if it needs it. otherwise, just a can of carb cleaner and a toothbrush ought to refresh things niceley. add a pertonix or crane and ditch those points while you're at it. |
| nebreitling |
Mar 6 2005, 07:46 PM
whoop -- ya beat me dave (and as usual, your response was more thoughtful and accurate)... (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
| Type 4 |
Mar 6 2005, 07:57 PM
Member ![]() ![]() Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Here is a How To for the dizzy Not a 914 FI but a step by step.
http://www.glenn-ring.com/010/ |
| bd1308 |
Mar 6 2005, 08:03 PM
alright dave....i'll give it a try.
| bd1308 |
Mar 6 2005, 08:08 PM
okay anybody have a way to drive this out without fancy tools.....i have a hammer and a philips head screwdriver and maybe a wrench...mihgt have a nail...but no vice.
| Joe Ricard |
Mar 6 2005, 08:12 PM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Put your tools down and back away from the car.
You need a drift and a soft jaw vice to hold th shaft till while you drift the pin out. Have you already taken the vacuum can off? What is the condition of the shaft? does it wobble side to side? or just up and down? When you get the point plate off was it all crudy? |
| bd1308 |
forgot pic
| bd1308 |
Mar 6 2005, 09:29 PM
got it done....i cleaned everything out with a toothbrush and carb cleaner.....now I am off to the car to see if it works.
| bd1308 |
Mar 6 2005, 09:58 PM
now i finally see the real power of the 2.0.....it ROCKS! the centrifugal advance mechanism was rusted out and didn't work wel at all. I simply took everything apart and then cleaned everything out with a toothbrush and carb cleaner....the dorm people went nuts (SHHHH dont tell them) and everyone on my floor is high....BUT my car runs like a champ
| Joe Ricard |
Mar 7 2005, 09:27 AM
Welcome to the real world of owning a 914. Take it apart fix it in the living room (or dorm room) and have it running by Monday to go to work.
(IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) |
| bd1308 |
Mar 7 2005, 12:33 PM
exactly what i did.....now i just need a AAR so i dont have to drill on the gas for a minute or two until the car starts idling (but it does idle at a clean 1000...beautiful) I now have renewed hope for my car!
| Joe Ricard |
Mar 7 2005, 02:32 PM
So are you goingto still need my 1.7L motor??? I already got the money spent (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
| bd1308 |
Mar 7 2005, 03:05 PM
well joe....i think not. I thought my problems were more mechanical than electronical, but when i began diving into the ignition side of my car, i learned vast amounts of knowledge and fixed my drivability issues....i just need a AAR now |
| Aaron Cox |
Mar 7 2005, 03:25 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
LOL.... ask my roommate about the carb rebuilds i have done in here (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) also... hogging out gauges with a dremel and building a 904 gauge....aww....the smell of epoxy (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) |
| Aaron Cox |
good luck! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
| bd1308 |
Mar 7 2005, 03:28 PM
aaron, i think somebody here has one.....i think it was scooter311 from the bird forum or something, or maybe it was someone else....or maybe i'll just buy a 1.8 AAR and make that one work.... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Lo-Fi Version | Time is now: 30th April 2026 - 12:13 AM |
