Sway bar question. |
MikeM |
Oct 6 2015, 02:44 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all..
I was under my car today, 74 2.0 liter, and noticed that my factory front sway bar is not centered. By that I mean that it sticks out of the body on the right side by a good 1.5 inches more than the drivers side. This puts the bracket that the bar bolts to very close to the strut. I mean really close. Is this a problem? And if so, how could I fix this? I loosened the links but the bar will not move. Thoughts? Mike |
rjames |
Oct 6 2015, 03:03 PM
I'm made of metal Group: Members Posts: 3,924 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Hi all.. I was under my car today, 74 2.0 liter, and noticed that my factory front sway bar is not centered. By that I mean that it sticks out of the body on the right side by a good 1.5 inches more than the drivers side. This puts the bracket that the bar bolts to very close to the strut. I mean really close. Is this a problem? And if so, how could I fix this? I loosened the links but the bar will not move. Thoughts? Mike Grab a hammer and a block of wood and tap the end of the bar it until it's where you want it. Check it periodically to ensure it's not up against the strut. |
MikeM |
Oct 6 2015, 03:10 PM
Tried that. Didn't move at all!! What if I was to loosen the 3 bolts on the plate where the bar goes through?
mepstein |
Oct 6 2015, 03:19 PM
914-6 GT in waiting Group: Members Posts: 19,257 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
MikeM |
Oct 6 2015, 04:07 PM
OK thanks. I'll give that a try.
Mike |
Matt Romanowski |
Oct 6 2015, 09:09 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
You can then put a piece of pipe, rubber, hose clamp, etc on each side to keep it basically centered.
ThePaintedMan |
Oct 6 2015, 09:15 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
MikeM |
Oct 7 2015, 08:58 AM
Thanks George. Looks like a good idea. Now, where to find those???
Mike |
ThePaintedMan |
Oct 7 2015, 09:41 AM
You order them from that link - McMaster has all kinds of fun goodies if you're into fabrication, etc. Go with the two-piece clamp on collar. Check the OD of your swaybar first before ordering.
Lo-Fi Version | Time is now: 8th May 2024 - 05:19 PM |
