Transmission ID and Value Question |
sgh |
Oct 8 2015, 08:41 AM
Newbie Group: Members Posts: 29 Joined: 25-October 06 From: NE IL Member No.: 7,094 |
Hey guys, need some help identifying a transmission that I have. It is a 5sp with a serial number of HA06115. I cannot find a type number or any other numbers anywhere on the case. The website below has a serial number range of HA05084 - ? for a MY74 914 and HA05085 - ? for a MY75 914. 7:31 R&P with gear ratios AFNVZd.
http://www.blueskymotorsports.com/index.ph...17&Itemid=6 Is that what I have? Any idea as to the value of the transmission is good working condition? Thanks for the help. |
brant |
Oct 8 2015, 08:52 AM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the tricky thing is the definition of good working condition
without pulling the stack and having the experience to evaluate the 1st/reverse slider its tough to estimate the wear if it crunches at all down shifting into reverse at a full stop then the slider is worn and very expensive to replace. cores of unknown condition a low of 50 maybe 150 if driveable rebuilt 700 and up depending on the number of new parts and cost of rebuild (which can easily run 2k) |
Dave_Darling |
Oct 8 2015, 10:33 AM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The gearing for all 914 transmissions (except the Six) was the same. The only real year-to-year differences were that the 70-72 were tail-shifters, and the 73-76 were side-shifters.
--DD |
sgh |
Oct 8 2015, 10:52 AM
Thanks guys. The transmission is drivable as I had it in a car as a temporary unit. I do not remember any excessive crunching other than the typical 901 patience you need when shifting into 1st and reverse.
Maybe I'll just put it in the classifieds for a reasonable number. I have absolutely no use for it. |
Lo-Fi Version | Time is now: 28th April 2024 - 02:50 AM |
