what size 2.0 can ya build with webber ICT 34's carbs, need building specs... |
stugray |
Oct 13 2015, 11:42 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Traditionally, one would not build an engine to suit a specific set of carbs... especially ICTs. They aren't worth much and really only belong on Beetles or a MPG-oriented engine like a 1.7. I would think if you were going through the trouble of rebuilding an engine, you'd start with your desired displacement/purpose first, then source a set of appropriate carbs for your needs. Otherwise you're leaving a lot of performance on the table. Sort of like saying: I already have this Type I generator bracket.... if I build up a type I, how can I fit it in a 914.... (IMG:style_emoticons/default/chair.gif) In the overall scheme of things, buying a used set of carbs is a relatively small expense when compared to the total cost of building a type-IV from the ground up. I spent $220 to balance my rotating assembly and about $275 for a pair of used IDFs. IIRC - someone sold a pair of good IDFs PLUS a spare for $75 (those type deals don't pop up every week though) |
rhodyguy |
Oct 13 2015, 12:48 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
second thing i would do is determine what carbs, or ANY fuel delivery system, i would need for my desired engine. third would be double check everything. fourth is to proceed.
i'm leery of the as is bottom end and the displacement increase. for a stock cammed 2.0 i'd get a set of 40s, a nice linkage, a better than 009 distributor, a set of cb talls (used=1/2 price or less shipping included), some filters, low pressure rotary pump and be done with it. |
flmont |
Oct 13 2015, 05:52 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
See,..its a problem when ya don't know that much about this stuff, (Iam learning).But since they came on my 2.0 I thought they must have been enough to run that,So I thought well then, how large can I build,..But Mark Henry...stole all my thunder,..So now,(Thanks Mark). I know I need bigger carbs to build bigger,..which I understand,..So they were a cheap replacement for the FI system....as it would seem.. So I get to start over,....
flmont |
Oct 13 2015, 05:56 PM
Now,..what can I build with stk crank and rods,...and iam willing to rework what ever else I can,... to get a strong running 2.0,.most likely using bigger carbs,..or a aftermarket FI system down the road,..???? Thanks Guys,..I appreciate the help....Frank
ThePaintedMan |
Oct 13 2015, 06:03 PM
With 96 mm pistons and cylinders, that makes it a 2056.... a well respected and fairly simple swap. Most of the time that means you can keep the stock oil cooler as well and the engine should stay pretty cool (if tuned correctly and driven appropriately). A lot of people say the 2056 is the engine that the car should have come with.
Weber 40s or Dellorto 36s put you right in the ballpark for that engine. You could run the stock FI as well, if you can source all the parts and learn how to tune it. Any bigger displacement though, and you really have to start considering carbs only. The good news is you can probably sell the 34 ICTs on thesamba.com to one of the bus guys. They like them on their 1.7 engines! |
stugray |
Oct 13 2015, 08:13 PM
Exactly what George (above) said.
But - decide: Carbs or FI - FIRST, then choose a cam. |
Oct 13 2015, 08:25 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Any bigger displacement though, and you really have to start considering carbs only. That, or aftermarket FI ... (IMG:style_emoticons/default/shades.gif) |
flmont |
Oct 13 2015, 08:26 PM
I think carbs,..kinda what that old fashioned oil and gas smell in my sports car,...could I punch up to 101 jugs or is that to much metal milled from the case,..I would love cam and valve sizes,..I am looking for torque of course but 80-100 MPH hi-way speeds...??? TIA Frank
rhodyguy |
Oct 14 2015, 08:24 AM
A whole new can of worms. Too much displacement and you can forget being able to run heat exchangers. As mentioned the 2056cc engine is a relatively cost effective upgrade without reinventing the wheel. The use of 100 or plus pistons and cyls is debatatable. Some have had success, some haven't. "Learning" and asking question is what world is for. Collectively, we want you to be productive in your ownership and not spend a fortune climbing the learning curve. At times responses might seem abrupt but that's not the case. Let your thread run it's course. Process the info, and start finalizing the engine plan. We don't want you to spend a bunch of $ only to be frustrated and unhappy with your 914.
Choose a path and stick to it for now. Don't plan your engine with the thought of what you're you might do 5k miles down the road. Swapping the new carbs for fuel injection? Not smart. You'll have plenty of time to spend money further down the road. |
flmont |
Oct 14 2015, 05:50 PM
I agree with that rhodyguy,...so,..can U give me specs for the 2056,..I know 96's,..and then what cam to use....I assume stk heads,crank and rods..?? and what size carbs will I need...Thanks,
or is there info somewhere,..??? |
stugray |
Oct 14 2015, 06:03 PM
I agree with that rhodyguy,...so,..can U give me specs for the 2056,..I know 96's,..and then what cam to use....I assume stk heads,crank and rods..?? and what size carbs will I need...Thanks, or is there info somewhere,..??? Stock 2.0L heads rods & crank. no need to oversize valves 96mm jugs with keith black pistons (europeanmotorworks.com) Weber 40 IDF carbs with 28mm Venturis (for steet driveability) Tangerine racing throttle linkage webcam 86b cam and lifters (buy them together). Tangerine racing headers if you dont need heat. |
flmont |
Oct 14 2015, 10:04 PM
Great,.. thanks....I guess it should obviously be balanced,...and what Comp ratio should I be at..??,..the 2056 is what,.. a 125 HP at the crank,..with pretty good torque,..Iam guessing...Thanks Frank
rhodyguy |
Oct 15 2015, 07:18 AM
this was the recommended setup for running 44idfs on a 2056 with the older correct type 4 store cam for carbs, HAM heads, and using heat exchangers. venturies reduced to 32mm, 50 idle jets, 145 main jets and F11 air correction. this would be for near sea level. pick up a good used set of the cb performance tall intake manifolds. use NEW correct for head version stock phenolic spacer/gaskets under the the intakes. Triad cross bar linkage or a tangerine cable pulley linkage. 40s should work, especially if you can mimic the above recommendations.
flmont |
Oct 15 2015, 10:35 PM
Sweet,...Thanks....rhodyguy...Ill work on this..
Lo-Fi Version | Time is now: 6th June 2024 - 05:37 AM |
