Displacement increase, D-Jet related |
914werke |
Mar 7 2005, 10:31 AM
"I got blisters on me fingers" Group: Members Posts: 10,058 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So knowing that stock d-jet in notorius for not tolerating major changes to the OE recipe the Q: is if I take a running stock 1.7 & swap the P&C's off of a 1.8 will the FI give me fits? Is there a differance or benifit from using the heads off the 1.8? (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Mueller |
Mar 7 2005, 11:02 AM
Rich....
I'm running a 1.7 D-jet injection setup on my 1.8 longblock...runs great....Andy has a recalibrated MPS for me, but I have not gotten around to picking it up and installing it. So far no problems.... |
davep |
Mar 7 2005, 11:03 AM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I'm sure you could use 1.7 FI on a 1.8, there is not too much difference. You might want to fiddle with injectors though. Maybe just a little increase in fuel pressure might do it. The 1.8 heads are much better than the 1.7 version.
Bleyseng |
Mar 7 2005, 12:15 PM
You get more hp out of the domed 90mm pistons if that is what you have. The 1.8 914 heads have better valve sizes than the tiny 1.7 heads but you can't use the 1.8 heads with the 1.7 pistons sooo you should just swap in the 1.8 stuff. With a few minor adjustments the 1.7 Djet will run fine. If you have good used 90mm pistons sell them.
Geoff |
Lo-Fi Version | Time is now: 14th May 2024 - 05:02 AM |
