Couldnt be happier but...., Air filter?? |
Jonnydaub |
Oct 11 2015, 06:47 PM
Newbie Group: Members Posts: 39 Joined: 27-August 15 From: Omaha, NE Member No.: 19,108 Region Association: Upper MidWest |
I couldn't be any happier, finally got my barn find 914 running after troubleshooting the whole fuel injection system I had some clogged injectors. Props to blue6 for the hookup on the New wheels as well. But my question is I can not find a air filter for my 1.7 at all. Any help would be nice. Its a 73 1.7
Oct 11 2015, 07:53 PM
Well, there is a VW air filter that works, but it needs some modifications and
I do not recall the part number. the original oil bath filter for the 1.7 works great and never needs a filter replaced so you may need to find one of those because the air filters for the stock box are NLA. |
Jonnydaub |
Oct 11 2015, 08:13 PM
Well, there is a VW air filter that works, but it needs some modifications and I do not recall the part number. the original oil bath filter for the 1.7 works great and never needs a filter replaced so you may need to find one of those because the air filters for the stock box are NLA. See now i didnt know that. Didnt know it was a oil bath filter. Makes sense why its that color. I just thought it was dirty (IMG:style_emoticons/default/headbang.gif) . How can i save the filter imhave now just submerge it back in oil or what? Im learning cut me some slack haha |
zipedadoo |
Oct 11 2015, 08:15 PM
Member Group: Members Posts: 135 Joined: 23-January 14 From: Arizona Member No.: 16,921 Region Association: None |
No........the oil bath does not have a filter. Just some oil in the bottom of the housing to catch dirt in the incoming air.
Jonnydaub |
Oct 11 2015, 08:18 PM
Any aftermarket mods to get rid of that setup?
Oct 11 2015, 08:19 PM
If you have an oil bath filter, the later cars had paper ones...
If it's oil bath then it has a rounded bottom with an orange line at the bottom to show you how much oil to put in. Clean it out, wipe out all the old oil, see if it has that line. If you have doubts, post a picture of the air filter housing. Rich |
Jonnydaub |
Oct 11 2015, 08:37 PM
Thank you will do, my filter is rounded with an orange lining . The car was sitting for 23 years so all the oil is dried up
Blue6 |
Oct 11 2015, 08:41 PM
Senior Member Group: Members Posts: 1,035 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
Glad you're pleased with the wheels, reach out toBruce Stone (bdstone ) here if you need air filter parts. He seems to come up with everything.
Mr. Olympic Blue 2 You |
Oct 11 2015, 09:59 PM
Member Group: Members Posts: 134 Joined: 7-September 10 From: Puyallup, WA Member No.: 12,150 Region Association: Pacific Northwest |
73 914 1.7 is the only year of the paper filter which was discontinued...
Bosch part #73349 Lucas part #F787 They come up once in awhile...check Samba and ebay. Shoot me a pm and Ill see if I have one I can sell you in the meantime. (IMG:style_emoticons/default/drunk.gif) Andrew |
stinkindiesel |
Oct 13 2015, 12:50 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I'm in the same boat, and have done some looking around for a filter that is close enough to fit with a little cutting or gasketing.
Below is some info I posted a while back. I still haven't gotten my 1.7 back together far enough to need an air filter, so I haven't actually tried any of these yet. Dimensions: Mann C2180 (OEM, NLA) 124mm ID 207mm OD 82mm tall Champion AF103 (NLA) 125mm ID 205mm OD 82mm tall The K & N E-1040 160mm ID 211mm OD 83mm tall Motorcraft C2OZ9601AR (FA3R) 3.225" tall (81.9mm) 8.313" OD (211.1mm) but can't find an ID for it. I also see slight variations on dimensions depending on where you look. Champion 70567 (1980 Ford F150 w/ 300 I-6) 8.410" OD (213.6mm) 6.630" ID (168.4mm) 3.230" tall (82.0mm) Gary |
Jonnydaub |
Oct 13 2015, 02:12 PM
said screw it and am doing a "cold air" intake. not really cold air but its far better then the original oil bath I think at least
Larmo63 |
Oct 13 2015, 03:23 PM
I think Automobiles Atlanta has them. That is where I got mine.
Kansas 914 |
Oct 13 2015, 04:01 PM
said screw it and am doing a "cold air" intake. not really cold air but its far better then the original oil bath I think at least Oil bath air filters work really well, just a bit messy at times, usually the first time. (IMG:style_emoticons/default/smile.gif) |
era vulgaris |
Oct 13 2015, 05:55 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
said screw it and am doing a "cold air" intake. not really cold air but its far better then the original oil bath I think at least Far better? No. Different? Yes. Each have their own advantages and disadvantages. But there's nothing wrong with either one. Unless you have a high horsepower fire breathing monster of an engine, I doubt you'll notice any difference in performance between a paper filter and an oil bath filter. One definite pro to an oil bath is that you never have to buy filters for it. Also, it won't become restricted as it fills with dirt and dust the way a paper filter will. The flow rate is the same whether the oil is new and clean or old and filled with dirt and dust. |
stinkindiesel |
Oct 14 2015, 01:17 PM
I think Automobiles Atlanta has them. That is where I got mine. I've checked AA from time to time. They will tell you they have them, but will point you to the 2.0L square filter. Half the people there don't seem to realize the 1.7 and 2.0 use different filters. They've been OOS on the 1.7L round filter for a long time. Gary |
914_teener |
Oct 14 2015, 04:11 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
There is one you can order from Oreilly.....I can get the number when I get home. It is really close to the orig and works fine.
Mark Henry |
Oct 14 2015, 04:28 PM
I'm another one that says there's nothing wrong with a oil bath filter, in fact the "cold air intake"s IMHO a downgrade.
stinkindiesel |
Oct 15 2015, 02:47 PM
There is one you can order from Oreilly.....I can get the number when I get home. It is really close to the orig and works fine. Do tell. I've checked my local Oreilly, and haven't found anything closer than the Ford F100 filter that's a little too big around to seat in the filter box without some help. Gary |
zipedadoo |
Oct 15 2015, 04:51 PM
I did some reasearch on this subject awhile back and this is what I found on the internet..............(IMG:style_emoticons/default/wink.gif)
An oil bath air filter is not 100% efficent, ever. Something like 98-99%. So some dirt gets through to the engine. A new paper element air filter is arround 99.98% efficent. Once it gets a little dirty it becomes 100% efficent. A paper element filter will plug up eventually. A oil bath filter won't. I have heard the military still uses oil bath on some applications because its better to dust a engine than to be dead. But I could not confirm that. |
Oct 15 2015, 06:27 PM
Oil bath does the best job.
Lo-Fi Version | Time is now: 14th May 2024 - 08:21 PM |
