Roadcourse racers: oil cooling |
Stark 01 |
Oct 12 2015, 11:10 AM
Racing newbie Group: Members Posts: 43 Joined: 26-May 14 From: Concord, NC Member No.: 17,404 Region Association: South East States |
Hello to everyone here at 914 World!
A question for all the experienced roadcourse racers: with a 2.1L (over bored 2.0) with a higher than stock compression ratio of about 10:1, what is the preferred oil cooling method, or at least the minimum. Option A: stock, with stock baffled pickup Option B: extra capacity, such as SCAT, with stock cooler Option C: external oil cooler at front of car. Option D: ??? If option C, in addition to the cooler and lines and adapter kit, would there need to be a change in the oil pump from stock? I am trying to get a handle on this, and am very new to the 914 and it's strenghts/weaknesses. |
ChrisFoley |
Oct 12 2015, 12:14 PM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I'd go with a front mounted cooler for a full time track car.
The stock cooler will be totally inadequate. A bigger than stock pump is advised, and use dash 12 lines. |
stownsen914 |
Oct 12 2015, 01:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
By SCAT, did you mean a deep sump? I'm curious to see if that's still a recommended option. I used a "tuna can" pickup extender on a stock-ish 914 track car years ago.
Stark 01 |
Oct 12 2015, 02:22 PM
yes, I was referring to a deep sump SCAT. I understand they are not exactly "coolers", but a larger sump will help with pickup problems I was having with the stock oil system in the corners.
Racer |
Oct 12 2015, 03:51 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
I ran a "tuna can" on my stock 1.7, but when I went to a 2056, I also installed a front mounted cooler. Car never ran hot. I did run a temp. oil cooler up against the engine lid as a stop gap, but much preferred the front location.
fwiw, my '76 was a stock 2.0, but when I bought it the previous owner ran both a front mounted cooler and an accusump (vs the tuna can sump extender). I know the accusump doesn't help with cooling, but its another item some folks want in a high g track car with a wet sump. |
Stark 01 |
Oct 12 2015, 04:34 PM
I'm not sure if those tuna cans are still available.
What oil pump did you use with your setup? |
carr914 |
Oct 12 2015, 04:51 PM
Racer from Birth Group: Members Posts: 118,404 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
carr914 |
Oct 12 2015, 04:52 PM
ThePaintedMan |
Oct 12 2015, 08:00 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Tuna cans work plenty fine on anything but HUGE slicks - I never had any drops in pressure in T1 or T17 at Sebring. I've heard the SCAT sumps are just another place for oil to leak and stick down even further than a tuna can. Definitely need that cooler though - follow Chris and you'll never go wrong.
Jetsetsurfshop |
Oct 12 2015, 08:09 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
George (paintedman) and I ran my car in an 14 hour endurance race in central Florida! We never seen temps over 210 degrees.
Heres my set up front cooler with -12 lines (Mocal) tuna can (didn't use the big under engine sump, worried about the curbing) type 1 oil pump 2 quart accusump We ran at WOT for hours, around 800 miles. It was insane! (IMG:style_emoticons/default/driving.gif) |
Stark 01 |
Oct 13 2015, 08:19 AM
Excellent, thank you all!
brant |
Oct 13 2015, 09:07 AM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
back when we raced a T4, we did have pressure drops in most corners on moderate DOT tires.
We wired in a 2nd oil pressure sensor at 15psi to a big 2nd light I saw it flicker often... so my take away is that maybe I didn't get down to 3psi in the corners..... but I did get to 15psi in the corners which I felt was inadequate for high rpm the accusump solved that problem and these were big oil pump/tuna can motors just my 2 cents |
ThePaintedMan |
Oct 13 2015, 11:16 AM
...Brant's a much better driver than I am, lol. Not surprising he saw a pressure drop... also my car was a stock motor, which probably wasn't cornering hard enough to slosh it away from the pickup. Still, a tuna can is a good idea and an Accusump an even better one. Shane's car is a hoot to drive, even on the DOT tires... the way he had it setup with the tuna can, Accusump and front cooler made it bulletproof.
brant |
Oct 13 2015, 03:42 PM
Lo-Fi Version | Time is now: 5th May 2024 - 10:37 AM |
