WTB: stock rear springs or...., decent adjustable rear struts complete |
malcolm2 |
Oct 15 2015, 12:06 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I guess I am finally tired of looking at my leaning car. I have measured (not weighed) several times and it is only the drivers rear that is noticeably lower.
Not sure if I need springs or the whole strut. But I should make the change in pairs. The stock springs are the 100 lb ones, right? If I go with the complete change out, figured I'd get (used) adjustable to replace my KYB of unknown age. Clark |
Oct 15 2015, 12:09 PM
914-6 GT in waiting Group: Members Posts: 19,268 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Get boge struts and 100lb springs/pair. I know Pmb has the struts at good prices, may have the springs. You'll like your car so much better when you throw away the kyb's.
KevinGieg |
Oct 15 2015, 01:38 PM
cut, weld n' wrench Group: Members Posts: 5 Joined: 8-January 15 From: Tucson Member No.: 18,309 Region Association: Southwest Region |
0396 |
Oct 15 2015, 03:27 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Kyb are only good for moving the car around in the garage.
Mblizzard |
Oct 15 2015, 05:52 PM
Clark I have a good set of springs and KYBs. Come get them.
malcolm2 |
Oct 15 2015, 05:56 PM
Get boge struts and 100lb springs/pair. I know Pmb has the struts at good prices, may have the springs. You'll like your cat so much better when you throw away the kyb's. Make sure it's not the lower trailing arm mount it's failing instead of your spring. I believe i am good on them. Both trailing arms have been removed, blasted, painted, re-bearing'd, re bushed with elephant racing rubber (fronts too) and pivot arms. Even if they are, i agree the KYB should go. But I may need an interim fix. Mike, i may take u up on it to really see if it straightens up. |
Lo-Fi Version | Time is now: 13th May 2024 - 12:53 PM |
