Momo Prototipo, Signal cancelation |
DavidSweden |
Oct 15 2015, 02:52 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I have got myself a Momo Prototipo 350 mm and an adapter hub to mount it onto the steering column.
My question: Do I need anything else to get the signal cancellation working? Thanks in advance |
EdwardBlume |
Oct 15 2015, 03:06 PM
I have a Dino and I believe the canceler is a flange on the hub. If you have one on your adapter, you should be good.
DavidSweden |
Oct 15 2015, 03:56 PM
I have a Dino and I believe the canceler is a flange on the hub. If you have one on your adapter, you should be good. The hub looks like this, no flange (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1444946190.1.jpg) |
TheCabinetmaker |
Oct 15 2015, 04:26 PM
The canceling ring should be moved to the new hub adaptor at those three screw holes
DavidSweden |
Oct 15 2015, 04:38 PM
Lo-Fi Version | Time is now: 17th May 2024 - 01:03 AM |
