I have got myself a Momo Prototipo 350 mm and an adapter hub to mount it onto the steering column.
My question: Do I need anything else to get the signal cancellation working?
Thanks in advance
EdwardBlume
Oct 15 2015, 03:06 PM
I have a Dino and I believe the canceler is a flange on the hub. If you have one on your adapter, you should be good.
DavidSweden
Oct 15 2015, 03:56 PM
QUOTE(RobW @ Oct 15 2015, 01:06 PM)
The hub looks like this, no flange
TheCabinetmaker
Oct 15 2015, 04:26 PM
The canceling ring should be moved to the new hub adaptor at those three screw holes
DavidSweden
Oct 15 2015, 04:38 PM
QUOTE(The Cabinetmaker @ Oct 15 2015, 02:26 PM)
Ok, I could not remember seeing if the canceling ring could be removed it was a while since I last removed the steering wheel. Thanks for letting me know.
Regards David
