Steel roof, Whos done it? |
DavidSweden |
Oct 16 2015, 02:52 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am thinking about ditching the taga top and installing a permanent steel roof.
If any member has done this and have some advice to share I would be pleased to hear it, also pictures showing the work in progress would be helpful Thanks in advance |
ConeDodger |
Oct 16 2015, 02:57 PM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Patrick Motorsports and Joe Obrian (iirc)...
Oct 16 2015, 02:58 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Chris H. |
Oct 16 2015, 03:45 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
rgalla9146 |
Oct 16 2015, 03:59 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I'm interested.
And others I've spoken with are interested as well. At least two that have been shown here. A 924 /944 roof has a good basic shape for our cars but a bit of width has to be removed...... along with other surgery. 'Root' did the blue car. TC has owned it.........twice ? |
Harpo |
Oct 16 2015, 05:00 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Racer Chris as well AA has done this as well. Not an easy task
David |
Mark Henry |
Oct 16 2015, 06:40 PM
Couldn't you re-enforce and bond a F/G top on?
Seems it would save you a ton of work. |
Mueller |
Oct 16 2015, 06:59 PM
Couldn't you re-enforce and bond a F/G top on? Seems it would save you a ton of work. Steel is real (IMG:style_emoticons/default/smile.gif) Want a 'glass roof, get a 'vette (IMG:style_emoticons/default/lol-2.gif) |
PanelBilly |
Oct 16 2015, 07:19 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Restoration Design should make one
Oct 16 2015, 07:55 PM
rgalla9146 |
Oct 16 2015, 08:01 PM
Couldn't you re-enforce and bond a F/G top on? Seems it would save you a ton of work. I've had the same idea. Some modern cars have metal panels that are glued on. Corvettes have the skin glued to metal sub structures. Gluing the 'glass roof on our cars seems a natural. Some metal work will be needed to create enough surface area for the glue to be effective. The seam at the front of the fiberglass where the rubber seal is could be tricky but can be handled. |
Johny Blackstain |
Oct 16 2015, 08:02 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Restoration Design should make one Too little demand. Especially compared with the demand for 356 and early 911 parts. (IMG:style_emoticons/default/agree.gif) however, someone should make a set of blueprints for a kit. Not as expensive as tooling up for a kit that won't have a lot of demand & cheap enough for people to buy & then if they change their mind pitch or sell/give to someone else. |
Tom |
Oct 16 2015, 08:28 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Dan Root ( Root Werks) did a really nice one some years back. He sold it and it changed hands several times, been all over the country. I believe CAR914 had it at least once.
Tom |
Oct 16 2015, 08:51 PM
Restoration Design should make one Too little demand. Especially compared with the demand for 356 and early 911 parts. (IMG:style_emoticons/default/agree.gif) however, someone should make a set of blueprints for a kit. Not as expensive as tooling up for a kit that won't have a lot of demand & cheap enough for people to buy & then if they change their mind pitch or sell/give to someone else. Between the auto Atlanta thread and the stock targa roof, we have the template and info. It's the actual welding and metal shaping that is where all the work is. |
carr914 |
Oct 17 2015, 06:06 AM
Racer from Birth Group: Members Posts: 118,626 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I'm interested. And others I've spoken with are interested as well. At least two that have been shown here. A 924 /944 roof has a good basic shape for our cars but a bit of width has to be removed...... along with other surgery. 'Root' did the blue car. TC has owned it.........twice ? Yes, I've owned it twice - last I heard it was in New Hampshire. The roof was done nicely, some other things in the car not so much |
jpnovak |
Oct 17 2015, 11:09 AM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
I am currently helping a friend build a steel roof for his 916 replica. so far, the skin is coming along nicely. English wheel, plannishing hammers, shrinker/stretcher, brake and slip roll are all needed. Still have to work out the side seal issues.
There is A LOT of hours going into this. |
DavidSweden |
Oct 17 2015, 01:27 PM
I am currently helping a friend build a steel roof for his 916 replica. so far, the skin is coming along nicely. English wheel, plannishing hammers, shrinker/stretcher, brake and slip roll are all needed. Still have to work out the side seal issues. There is A LOT of hours going into this. Any pictures of the progress? |
Oct 17 2015, 01:44 PM
Racer chris/tangerine racing mentioned making a kit. I don't think it ever went any further than that but maybe he would revisit the idea with enough pre ordered. It won't be cheap. I once asked scotty to ballpark an estimate and he said $3,500. We'll never get enough takers to make it feasible for restoration design to make up a mold.
ChrisFoley |
Oct 18 2015, 09:17 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Racer chris/tangerine racing mentioned making a kit. ... I once asked scotty to ballpark an estimate and he said $3,500. ... I made two on customer cars at that price - as close to the factory design as I could. Probably the only big difference is the way I made the headliner - using a single piece of black textured ABS instead of taut fabric (or leather). The next fabrication/installation done here will be closer to $6000. This includes "frenching" the rain gutters into the windshield frame as the factory did. It's unlikely that I will make kits anytime in the near future, but I haven't ruled it out. There are numerous details which go into a faithful reproduction. |
Johny Blackstain |
Oct 18 2015, 09:39 AM
I made two on customer cars at that price - as close to the factory design as I could. Probably the only big difference is the way I made the headliner - using a single piece of black textured ABS instead of taut fabric (or leather). The next fabrication/installation done here will be closer to $6000. This includes "frenching" the rain gutters into the windshield frame as the factory did. It's unlikely that I will make kits anytime in the near future, but I haven't ruled it out. There are numerous details which go into a faithful reproduction. (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 03:32 AM |
