F/S Fans. 2 fresh air and 4 engine compartment heat fans, Engine compartment fans are NLA |
airheads |
Oct 20 2015, 06:43 PM
Newbie Group: Members Posts: 2 Joined: 31-March 08 From: c,ville P.A. Member No.: 8,872 Region Association: None |
For sale, a bunch of fans for your 914. One of the fresh air fans has a cracked plastic near a screw hole. The other one's flapper circles are a little rusty. $50 each plus shipping. One of the the four heat helping fans is missing it's plastic flapper and has a bent rim. $100 a fan, $75 for the bent one. Plus shipping. I can email better pictures.
Check out the pictures and tell me whitch one you would like. |
riccorman |
Oct 20 2015, 08:26 PM
Newbie Group: Members Posts: 4 Joined: 22-September 15 From: Oklahoma City USA Member No.: 19,189 Region Association: Southwest Region |
I would like the perfect fresh air fan. Sending pm now.
DRPHIL914 |
Oct 21 2015, 10:07 AM
interested in fresh air fan. can you test them , do you know for sure they work on all 3 speeds? my current fan only works on medium setting not low or high, and I switched out the controller thinking that was it but same result, so I have to assume the low and high settings are burned out on the fan itself.
thanks, Phil |
bdstone914 |
Oct 21 2015, 02:12 PM
bdstone914 Group: Members Posts: 4,518 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
interested in fresh air fan. can you test them , do you know for sure they work on all 3 speeds? my current fan only works on medium setting not low or high, and I switched out the controller thinking that was it but same result, so I have to assume the low and high settings are burned out on the fan itself. thanks, Phil The fan runs at one speed with 12 volts applied. The power is stepped down by the control. Pull it out from the dash and look at the contacts and the plastic in between it can melt and raise up causing the contact to lift off the board. Usually happens on the high speed. |
airheads |
Oct 24 2015, 01:16 PM
Front two fresh air fans sold.
Lo-Fi Version | Time is now: 12th May 2024 - 04:50 PM |
