Been trailer shopping, Wasn't sure if I should jump on this one, now open discussion |
Chris914n6 |
Oct 20 2015, 10:42 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Checked out this trailer today. Fixer upper. Not sure if it's worth it. His bottom dollar, 500.
16ft x 75in floor. 98in x ~19ft total. 12in rail height. Mostly 2in and 3in angle iron with 2x10 planks. Heavy enough I couldn't lift it a mm. Needs a pair of electric brakes, lights and wiring, 4 tires, at least 2 wheels (I might have that covered if I go 5x4.5" hubs), susp bushings. Also ramps. The floor droops across the middle, likely overloaded the angle. ?? Both axles curve a little, like they were made for a bit of camber. Plan for it is to move cars under 4,000lb to flip and the 914 to events. Also toying with making my own that's lighter, using rectangle or something. Haven't seen blueprints I like yet. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1445402568.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1445402569.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1445402570.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1445402570.4.jpg) The thunderstorm we had a few days ago flooded his yard, so its a bit muddy. |
messix |
Oct 20 2015, 10:58 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
i would pass even at that price.
the axles should have a "bend" the other direction. the cross supports are bent, the trailer has been abused severely. the whole thing is suspect. you will probably find cracks trough out the whole frame. |
carr914 |
Oct 21 2015, 04:35 AM
Racer from Birth Group: Members Posts: 118,603 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Pass
Oct 21 2015, 04:59 AM
914-6 GT in waiting Group: Members Posts: 19,270 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I've been offered trailers for free that look better than that one.
rgalla9146 |
Oct 21 2015, 05:32 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
$500. is 25% of a far better, more car friendly trailer.
Pass. |
EdwardBlume |
Oct 21 2015, 06:41 AM
EdwardBlume |
Oct 21 2015, 06:45 AM
I had one like this which is about $3500. The deck was nice, but the ramps sucked and loading a race 914 was like loading a tractor climbing the ladder....
EdwardBlume |
Oct 21 2015, 06:47 AM
I custom ordered one like this about 12 years ago. Got it with drop axels and a ducktail. About $2400 out the door new.
Krieger |
Oct 21 2015, 08:01 AM
Advanced Member Group: Members Posts: 4,707 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Run away! I got a 16' new dovetail, lower deck out the door fully licensed for 2800 in February.
aircooledtechguy |
Oct 21 2015, 09:12 AM
I'm looking for a similar trailer as well. Any day on CL a nice ready-to-go trailer can be had in the $2k range.
Don't trip over dollars to pick up dimes. . . Leave the fixer for the other guy. |
billh1963 |
Oct 21 2015, 09:27 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
If you are serious about towing long distances, get an aluminum one.
They cost good money (even used). However, they hold their value as well. I bet I could sell mine for what I paid for it. |
bulitt |
Oct 21 2015, 09:47 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Depends on the rating of your truck.
Big tex sells a car hauler for 1995$ here in NC. Tandem with wooden floor only weighs around 1500lbs. You can pop the center sections out to lighten it even more or keep in place to double as a utility trailer. For 3000$ I would go with a new enclosed. Trailer Thread- http://www.914world.com/bbs2/index.php?sho...&hl=trailer 7x14 |
arsprod |
Oct 21 2015, 10:42 AM
Member Group: Members Posts: 199 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
I'm trailer shopping too (for miata race car) and I've seen steel w/wood decked ones on craigslist in the $750-1000 range that look almost new. New ones below $2k. I'm looking for an aluminum 16 footer if anyone has suggestions. And suggestions on how to convince my wife that it's ok to park it in the side yard!
EdwardBlume |
Oct 21 2015, 11:27 AM
Run away! I got a 16' new dovetail, lower deck out the door fully licensed for 2800 in February. When I had a trailer everyone wanted to borrow it.... (IMG:style_emoticons/default/idea.gif) |
Chris914n6 |
Oct 21 2015, 04:21 PM
You guys do know I fix things for a living right? (IMG:style_emoticons/default/biggrin.gif)
Looks like about $1300 all in to get it right. Too close to the cost of a better trailer, and one that I wouldn't have to modify. Plus a 75" deck is kinda tight. Fun fact... the average car door is 11" off the ground. |
hot_shoe914 |
Oct 21 2015, 04:51 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
arsprod |
Oct 21 2015, 05:42 PM
Uhhh,.and if we don't live in memphis? |
hot_shoe914 |
Oct 21 2015, 06:37 PM
Uhhh,.and if we don't live in memphis? Maybe I will bring it to you. |
arsprod |
Oct 21 2015, 07:32 PM
Uhhh,.and if we don't live in memphis? Maybe I will bring it to you. Careful, I might take you up on that! |
arsprod |
Oct 26 2015, 12:49 PM
Uhhh,.and if we don't live in memphis? Maybe I will bring it to you. Careful, I might take you up on that! PM'd you - like to know your experience with Cherokee |
Lo-Fi Version | Time is now: 14th May 2024 - 10:44 AM |
