Which rear brakes for my /6? |
tornik550 |
Oct 26 2015, 05:37 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have wide A front calipers for my /6. I am trying to figure out which rear calipers I should use. I want to retain the use of an emergency brake. I plan on using my car for spirited street driving.
My options- Stock 914/4 rear calipers Or Ferrari 308, 914/6gt rear calipers |
colingreene |
Oct 26 2015, 05:45 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
I would keep the ones you have till you could find some 6 ones.
tornik550 |
Oct 26 2015, 06:07 PM
I should clarify that I already have Ferrari 308 and 914/4 rear calipers
914Sixer |
Oct 26 2015, 06:20 PM
308 should be the same as the 914-6 if my memory is correct. The bleeder is different but I can not remember where.
914forme |
Oct 26 2015, 06:23 PM
Bleeders end up being at the bottom on the 308 calipers, but they are vented. I would go 308, it you have them. Bleeding just gets a little tricky.
t collins |
Oct 26 2015, 06:34 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
got mine from PMB Performance
Attached thumbnail(s) |
Oct 26 2015, 07:48 PM
914-6 GT in waiting Group: Members Posts: 19,269 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Send your 308 calipers to PMB performance he'll put the bleeders in the right place and make an awesome set of brakes for you
Eric_Shea |
Oct 27 2015, 08:13 AM
The 308 calipers will retain the proper factory 1.6:1 bias ratio with the 48mm pistons of the Carrera fronts.
Krieger |
Oct 27 2015, 09:33 AM
Advanced Member Group: Members Posts: 4,707 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
(IMG:style_emoticons/default/agree.gif) I have the wide A in front with 308 calipers in rear. Just need to drill those 308 calipers for new bleeders. Works bitchin!
Harpo |
Oct 29 2015, 05:34 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Where did everyone find their 308 calipers. I have had no luck.
Thanks David |
Oct 29 2015, 05:50 PM
Krieger |
Oct 29 2015, 08:06 PM
I called a local Italian repair shop. He had a pair sitting around. $200. Paid a machinist to drill new bleeder holes. PMB for rebuild kits.
Lo-Fi Version | Time is now: 13th May 2024 - 08:58 PM |
