pics of rust I have found on the car |
jrblackbox |
Oct 26 2015, 05:48 PM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
[attachmentid=524
638][attachmentid =524642] Have not been able to remove the rocker panels yet, I'm thinking the rust isn't that bad to this point. What do you think? Attached image(s) |
G e o r g e |
Oct 26 2015, 06:00 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
what does the hell hole look like? interior behind seats?
the floor tar is hiding the real rust. the heater lever may be a sign of what you cant see under the tar. trunks don't look too bad. what does the underneath look like? |
G e o r g e |
Oct 26 2015, 06:01 PM
stevegm |
Oct 26 2015, 06:06 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
Pull the rocker covers. Then you will know what you have. What you are showing so far doesn't look all that bad. But, the longs will tell the tale. Along with under the tar in the pans, and the hell hole. |
altitude411 |
Oct 26 2015, 06:07 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
you haven't got to the rust on the floor pans yet... it there, under the tar (IMG:style_emoticons/default/dry.gif) Use a heat gun and putty knife to remove it. Ice pick on other areas to see if it's solid or rot. Picture of the hell hole is required. Paint hides a lot. (IMG:style_emoticons/default/welcome.png)
altitude411 |
Oct 26 2015, 06:08 PM
(IMG:style_emoticons/default/headbang.gif) DP #1
jrblackbox |
Oct 26 2015, 06:13 PM
what does the hell hole look like? interior behind seats? the floor tar is hiding the real rust. the heater lever may be a sign of what you cant see under the tar. trunks don't look too bad. what does the underneath look like? Behind the seats looks fine, the battery tray is rusty I have to get down there to get a better look. there is surface rust underneath the car,but no rot that i could find. I was picking at the dirt behind the rockers and from what I can see without removing them it looks pretty good. |
Lo-Fi Version | Time is now: 14th May 2024 - 03:52 PM |
