What distributor for my /6 2.7 build? |
tornik550 |
Oct 27 2015, 05:06 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
What distributor would be best to use for my build? I am building a 2.7l using JE 9.5:1 Pistons, E- cams and carbs. Simple is good for me. My car is going to be used for spirited street driving.
rudedude |
Oct 27 2015, 05:22 PM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
Which case?
tornik550 |
Oct 27 2015, 05:32 PM
2.7l- 7R
rudedude |
Oct 27 2015, 05:52 PM
I built essentially the same motor but used mod S cams from dougherty. I was able to find a 2.7RS distributor. the combination works quite well. I will try to find bosch numbers if you like otherwise have yours recurved.
Mark Henry |
Oct 27 2015, 06:04 PM
1/ Get the stock dizzy rebuilt and re-curved.
2/ Build a megajolt jr. (Ford EDIS) 3/ Get a MS and run ignition only. This one gives you the option to run FI in the future. 4/ Clewett Engineering has a crankfire ignition system. One option that won't work is locking out the dizzy advance and running the MSD programmable, the 911 cap and rotor doesn't have long enough legs to keep it in phase. |
screenguy914 |
Oct 27 2015, 07:04 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Here are a couple of candidates if you can find one:
67-68 S Distributor 69-71 S Distributor Advance curve info here: http://forums.pelicanparts.com/porsche-911...or-my-2-2t.html http://forums.pelicanparts.com/porsche-911...11-s-bosch.html Sherwood |
brant |
Oct 27 2015, 09:13 PM
Isn't the shaft a different size for an aluminum case early distributor? (67s) vs a 7R dist. shaft
Mark Henry |
Oct 28 2015, 05:48 AM
Here are a couple of candidates if you can find one: 67-68 S Distributor 69-71 S Distributor Advance curve info here: http://forums.pelicanparts.com/porsche-911...or-my-2-2t.html http://forums.pelicanparts.com/porsche-911...11-s-bosch.html Sherwood Guess you haven't seen what a yellow tag dizzy is going for lately (IMG:style_emoticons/default/biggrin.gif) For one in that shape I'd bet he'd be 3/4 of the way to a full MS fuel injection system installed. |
Peashooter |
Oct 28 2015, 06:55 AM
Member Group: Members Posts: 163 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
The early distributors will not fit into the later 7R case. I built a similar engine, my stock dist. is going out to Woods for recurve.
tornik550 |
Oct 28 2015, 07:00 AM
Approximately how much does it cost for a recurve?
Luke M |
Oct 28 2015, 07:06 AM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
jd74914 |
Oct 28 2015, 07:10 AM
Luke M |
Oct 28 2015, 07:19 AM
That's the guy in Mich. Barry is who I spoke with. He won't give you a total/hard $ amount until he looks over your dizzy first. Nice guy and seams to know his stuff. |
brant |
Oct 28 2015, 07:49 AM
Although prices will vary
Anyone care to throw a rough cost number out? Also curious about the recurve costs, even if its a range? |
JmuRiz |
Oct 28 2015, 09:36 AM
914 Guru Group: Members Posts: 5,426 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
That's the guy in Mich. Barry is who I spoke with. He won't give you a total/hard $ amount until he looks over your dizzy first. Nice guy and seams to know his stuff. That's the pricing answer you're looking for. It could be an easy fix for little money or a bigger issue for more money. Always watch out for people that price before seeing any porsche part in person and seeing what it really needs. |
tornik550 |
Oct 28 2015, 10:31 AM
Looking for a general idea on price. I know that no one can tell me an exact price. Am I looking around $100, $500, $1000, $1000000?
rudedude |
Oct 28 2015, 10:52 AM
I believe when I was thinking of that route 8-10 years ago it was like $300
tornik550 |
Oct 28 2015, 10:57 AM
Has anyone ever tired one of these distributors? Cost about $750. I currently do not have a distributor that will fit in my car so I would have to buy a core, rebuild it and then have it recurved. I would probably be close to (or more) to $750.
http://www.123ignition.nl/id/63.html |
JmuRiz |
Oct 28 2015, 11:49 AM
I've heard the 123 ignitions are just to replace a stock-ish curve.
With a hot rodded non-factory engine a recurve from someone that knows your specs or a custom crank-fire setup would be best. |
Oct 28 2015, 12:00 PM
914-6 GT in waiting Group: Members Posts: 19,269 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have one out of a running car for $250 + ship. Boss said its the right one for your car. If you buy it and for whatever reason don't want it, you can return it. Mark
Lo-Fi Version | Time is now: 13th May 2024 - 11:32 PM |
