What is this cover called?, Protective Plate for Rack & Pinion? |
dcecc1968 |
Oct 28 2015, 02:56 PM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
I recently replaced my pedal set and while I was under there, I noticed that my 914 does not have this part shown in the photo below (stolen from McMark 's Creamsicle thread) and I probably need this to protect my master cylinder, etc. What is the real name of the part circled in red ....so I can post a proper WTB add in Classifieds?
-Don |
jimkelly |
Oct 28 2015, 02:58 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
Oct 28 2015, 03:58 PM
I have one that needs a little tlc that you can have for free if you pm me your address. Mark
walterolin |
Oct 28 2015, 04:00 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
914rubber has the seals...
stugray |
Oct 28 2015, 04:33 PM
I assume that the two rear bolts that go in after that plate are actually installed?
I bought a parts car a few years ago, drove it home, then noticed that plate was missing and the bolts were NOT installed! - BAD PO! |
Chris Pincetich |
Oct 28 2015, 06:33 PM
Mine is in the basement, and I may have lost the bolts...
CAN anyone tell me exactly what bolts are needed to re-install it?? (IMG:style_emoticons/default/beerchug.gif) |
Oct 28 2015, 07:03 PM
Mine is in the basement, and I may have lost the bolts... CAN anyone tell me exactly what bolts are needed to re-install it?? (IMG:style_emoticons/default/beerchug.gif) Get under and look The two large bolts should still be on the car as they hold the suspension cross member in place. The other two bolts are 13 mm head m8 bolts about 1/2 inch long. |
jeffdon |
Oct 28 2015, 11:26 PM
Oy. I need to put mine on....
GregAmy |
Oct 29 2015, 08:01 AM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I need one of these too, if it's still available...
Chris H. |
Oct 29 2015, 08:47 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I'm going cross-eyed trying to find the seals on the 914rubber site (IMG:style_emoticons/default/confused24.gif) .
jimkelly |
Oct 29 2015, 08:56 AM
his pics are WAY too small. great products though.
Chris H. |
Oct 29 2015, 11:26 AM
I just can't seem to locate it. Probably could just e-mail them or call.
walterolin |
Oct 29 2015, 11:40 AM
Here it is: "Early 911/944/356 and 914 Steering Pan Seal Set"
"These replace the rack and pinion cover seals NLA OEM 90134116500" Mark's site does not show a 914Rubber part number, took me a while to find it, but it is there. |
Chris H. |
Oct 29 2015, 11:44 AM
dcecc1968 |
Oct 30 2015, 07:25 AM
Thanks guys. As my two sons & I work on this project, I'm always finding things on my 914 that are missing when I look at photos of other members 914s, some not so important, but some important like this part.
This forum has been gold to me! ...Thanks Mepstein I'll PM you. |
76-914 |
Oct 30 2015, 08:00 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
BTW Chris, I received that "dust shield" for the Subaru that you turned me onto. Perfect fit. Thx. (IMG:style_emoticons/default/beerchug.gif) |
Larmo63 |
Oct 30 2015, 10:43 AM
My car has the more heavy duty 911 style front cover on the suspension.
The good: It's beefier and stronger The bad: It's really heavy (My original 914 cover in crappy condition is available.) |
Chris H. |
Oct 30 2015, 10:50 AM
BTW Chris, I received that "dust shield" for the Subaru that you turned me onto. Perfect fit. Thx. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/thumb3d.gif) Sweet. I'm putting mine on this weekend. re: my front pan shield, I MIGHT win the "most cracked seals" award. Will post later. |
aufgates |
Oct 30 2015, 11:22 AM
Newbie Group: Members Posts: 14 Joined: 4-June 15 From: CT Member No.: 18,797 Region Association: None |
If anyone has a spare - please PM me, before I go off roading (IMG:style_emoticons/default/wink.gif)
SKL1 |
Oct 30 2015, 08:28 PM
Senior Member Group: Members Posts: 1,600 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
The German name in the parts catalog is undershutz. I needed one a couple months ago and put a WTB in the classifieds. Got several responses quickly and found a good used one for reasonable price.
Should be able to get a used one pretty easilly... (and yes, the 17mm bolts hold on the rear of the front suspension A arms- a VERY important bolt to have in there and properly torqued!!!) |
Lo-Fi Version | Time is now: 15th May 2024 - 10:26 AM |
