Which conversion is harder to accomplish/in a 914, A. porsche 2.7 or 3.0 engine or B. the suby 3.3/Turbo |
flmont |
Oct 29 2015, 08:30 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Iam wondering which one of the 2 engine conversions are easier to do,.wouldn't the oil cooled conversion be the easy and quickest way to go,..??? I realize engine cost is a BIG factor, but seems oil cooled would be easier FM
Oct 29 2015, 08:36 PM
914-6 GT in waiting Group: Members Posts: 19,270 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
A Porsche engine was an oem option, 914-6, and with a different motor mount, (pretty much) bolts right in.
GeorgeRud |
Oct 29 2015, 08:41 PM
The Porsche engine may be more money initially, but you'll be glad you chose it once you're done. It's a great project!
Larmo63 |
Oct 29 2015, 08:43 PM
Oct 29 2015, 09:48 PM
Easier is aircooled
76-914 |
Oct 30 2015, 08:45 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) Haven't done a P6 conversion but I can't see how it wouldn't be easier than a Subaru engine conversion.
Dtjaden |
Oct 30 2015, 09:14 AM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
I'm getting started on Porsche 2.7L conversion. I'll detail the process (although this has already been done) as much to keep me on track as to help others. What I do know is involved are the following:
914/6 oil tank and fittings Early (65-69) 6 bolt flywheel 914/6 motor mount Front oil cooler and associated lines and fittings 914/6 exhaust headers (or very expensive heat exchangers) You will also need to make a decision on the fuel system. I am going to initially use the stock 1974 CIS injection system that came with the engine I bought. I may later switch to Megasquirt injection since I currently have that on my 2056 4. I believe I can keep the cost below $3,000 plus the cost of the engine so a total of about $8,000. I know that a Subi could be done for much less but I like the purity of keeping a Porsche engine. |
914forme |
Oct 30 2015, 09:24 AM
Depends on your skills, and what you want. since you said harder, I will go this way,but it all is a perception questions.
(IMG:style_emoticons/default/agree.gif) Porsche -6 it is all nuts and bolts with a little bit of cutting for the oil tank. Get the pieces, could be done in a weekend. That makes it pretty easy. Now for the proper question, so we could give you a better answer. I want to know what the best engine is for my street driven in the city car, that I take out for a long drive once a month down the To me your usage case and what you want the car to be in the end would determine the final out come. Shifting gears as smooth as butter, with a modern car feel, Subaru all the way. If we could get Ian to build kits again, or even use Renegade Kit, it is a bolt in affair also, with minor cutting for cooling. Renegade Kit uses the factory transaxle, so no smooth as butter shifting. |
GeorgeRud |
Oct 30 2015, 09:26 AM
If you live in an area where you do need heat, spend the money on the heat exchangers now that they are once again available. They work great (and hopefully fit correctly now), and keeps the car functional as defrost is also a nice feature to have working.
If you're using a 2.7, you'll need to change the flywheel to work with the 914's transmission as well. Enjoy the project in good health! |
KELTY360 |
Oct 30 2015, 09:29 AM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
A turbo on a 3.3 Subie is a whole 'nother level of complexity. The 3.3 came NA from the factory.
914forme |
Oct 30 2015, 02:17 PM
A turbo on a 3.3 Subie is a whole 'nother level of complexity. The 3.3 came NA from the factory. Not as bad as you think really. It is just a stretched 2.2Ls so all them piston, rods, etc work. Custom headers and down pipes and your done. (IMG:style_emoticons/default/lol-2.gif) Highly oversimplified |
flmont |
Oct 30 2015, 05:15 PM
What trips me up is the wiring on the 3.3,..and the fact I cant fab anything like a radiator shroud,or weld tranny brackets,..Etc,..So yes,...914forme,..I did mean as far as skill goes,..and tools aswell,..yea, a sheet metal can brake some tin for me,..its the electrical wiring,..I need help with, But ,..also the stinger ECU is 1800.00,..maybe small car would be less $$,.but a early 2.7 install would be nice also,..no ECU,no rad,just oil tank and flywheel,..I wonder how close the money is either way,.both engines are close in HP ,..but rebuild cost,..on a 2.7....well we know that story,.. FM
76-914 |
Oct 30 2015, 06:03 PM
Or keep your eyes open and buy one already done.
patssle |
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I have a photo album that documents my 3.0L flat six conversion - pretty much what you see is what needs to be done!
http://imgur.com/a/k0Wtl |
Cairo94507 |
Oct 30 2015, 06:16 PM
Michael Group: Members Posts: 9,750 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I think a GT bodied 914 with a twin turbo Subaru boxer motor would be a hell of a car. If I had a deep deep pocket, that would be a fun car to have. I imagine a PMS build......
flmont |
Oct 30 2015, 06:24 PM
Hey,..Thanks Patssle,..That is great info,..would love to hear rhat engine,..??? LOL Frank
flmont |
Oct 30 2015, 06:26 PM
Oh absoultly Cairo,.. I couldn't even add up how much that would cost,...but, I would love to drive it !!!
flmont |
Oct 30 2015, 06:36 PM
Yea,..76-914,...I do truly like to build my own if at all possible,..thats how u learn your cars,...I did a top end on a 3.o ltr engine,..painted the car,..installed engine,.. drove car 3 yrs loved it,..I will do the same with the 914,.. the difference being no major mods,...I can remove and replace,..things no problem,...LOL
phillstek |
Oct 30 2015, 08:10 PM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
I have a photo album that documents my 3.0L flat six conversion - pretty much what you see is what needs to be done! http://imgur.com/a/k0Wtl Apologies for the hijack but...I took a look at your conversion blog and was wondering about your comment re: stainless braided oil line “I won’t use these again" Why’s that? Thanks |
KELTY360 |
Oct 30 2015, 09:24 PM
A turbo on a 3.3 Subie is a whole 'nother level of complexity. The 3.3 came NA from the factory. Not as bad as you think really. It is just a stretched 2.2Ls so all them piston, rods, etc work. Custom headers and down pipes and your done. (IMG:style_emoticons/default/lol-2.gif) Highly oversimplified Had no idea it was that simple..... (IMG:style_emoticons/default/shades.gif) Easy peasy. What a great looking setup. Bet that snaps your head back. |
Lo-Fi Version | Time is now: 14th May 2024 - 05:02 PM |
