911 Emergency brake, Pressing fittings on cable |
DavidSweden |
Oct 31 2015, 03:51 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am installing a 911 emergency brake. I am planning on making the fittings for the 911 brake end and the other to link to the existing fitting on the end of the 914 brake cable.
Question: I want to press the fittings onto the cable myself, any members done this? advice/guidance appreciated. Thanks |
Mike Bellis |
Oct 31 2015, 03:55 PM
JFJ914 |
Oct 31 2015, 03:56 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
I am installing a 911 emergency brake. I am planning on making the fittings for the 911 brake end and the other to link to the existing fitting on the end of the 914 brake cable. Question: I want to press the fittings onto the cable myself, any members done this? advice/guidance appreciated. Thanks Find a sailboat rigger, they'll have fittings and tools. |
DavidSweden |
Oct 31 2015, 04:09 PM
QUOTE Find a sailboat rigger, they'll have fittings and tools. Good idea regarding sailboat rigger. I looked at the Tangerine part, I may be mistaken but i don't see how it will pull on both of the expanders, there is no sheath to press on the outer expander, or have I got it wrong? |
Mike Bellis |
Oct 31 2015, 07:33 PM
QUOTE Find a sailboat rigger, they'll have fittings and tools. Good idea regarding sailboat rigger. I looked at the Tangerine part, I may be mistaken but i don't see how it will pull on both of the expanders, there is no sheath to press on the outer expander, or have I got it wrong? The tube is welded to the trailing arm and does not move, since it's fixed you only need to pull on the cable. The 911 sheath is completely flexible and has to push on the backing plate to pull the cable. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:05 AM |
