Engine Rebuild? |
Engine Rebuild? |
Gearren |
Mar 10 2005, 06:25 PM
Member Group: Members Posts: 91 Joined: 18-July 04 From: New Bern, NC Member No.: 2,362 |
Can I use the 2270cc engine rebuild kit from type4parts.com on my 73 2.0 engine without any maching or other extra steps. Also will I need to get bigger than the 40idf's that I have now.
redshift |
Mar 10 2005, 07:02 PM
No, there will be machining, and some more machining. There is never a time of no machining, the machining may not cost an arm, and a leg, but it will cost at least a small piece of ass.
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) M |
Type 4 |
Mar 10 2005, 08:04 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Actually there is NO machine work required.
I supply a set of rods that I have made that clear the case and cam without any clearaning. The big end caps are more compact than the CB or Scat H beam rods. I had these made just for the stroker crank, cam and case roof clearance issue. All you need is a case and you can build up a 2270. |
swood |
Mar 10 2005, 10:28 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
....and here we go! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
wrpspddrvr |
Mar 10 2005, 11:40 PM
Member Group: Members Posts: 333 Joined: 22-December 04 Member No.: 3,317 Region Association: None |
Woo! (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) Cole (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
skline |
Mar 10 2005, 11:46 PM
So Jake is the inventor of the combination of a 78.4 crank with 96mm pistons? You must have been doing this since the late 70's, you have more experience than I thougth. I knew a guy in High school that did that combination and that was in the late 70's. He was all into VW racing. He used to run out at OCIR.
azbill |
Mar 10 2005, 11:55 PM
Member Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region |
Jake - competition is good for your soul! You cann't get all of the business. (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 04:19 AM |
