Can I use the 2270cc engine rebuild kit from type4parts.com on my 73 2.0 engine without any maching or other extra steps. Also will I need to get bigger than the 40idf's that I have now.
redshift
Mar 10 2005, 07:02 PM
No, there will be machining, and some more machining. There is never a time of no machining, the machining may not cost an arm, and a leg, but it will cost at least a small piece of ass.
M
Type 4
Mar 10 2005, 08:04 PM
Actually there is NO machine work required. I supply a set of rods that I have made that clear the case and cam without any clearaning. The big end caps are more compact than the CB or Scat H beam rods. I had these made just for the stroker crank, cam and case roof clearance issue. All you need is a case and you can build up a 2270.
swood
Mar 10 2005, 10:28 PM
....and here we go!
wrpspddrvr
Mar 10 2005, 11:40 PM
QUOTE (swood @ Mar 10 2005, 11:28 PM)
....and here we go!
Woo!
Cole
skline
Mar 10 2005, 11:46 PM
So Jake is the inventor of the combination of a 78.4 crank with 96mm pistons? You must have been doing this since the late 70's, you have more experience than I thougth. I knew a guy in High school that did that combination and that was in the late 70's. He was all into VW racing. He used to run out at OCIR.
azbill
Mar 10 2005, 11:55 PM
Jake - competition is good for your soul! You cann't get all of the business.
