Restoring white headlight surrounds |
PancakePorsche |
Nov 12 2015, 01:22 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
I have typical cruddy, yellowed white headlight surrounds on my repainted car and I want to restore them the best I can.
Painting them would be easy and look o.k. but I know it is kinda frowned upon by the purest because it is not original and I agree. Any known tricks out there ? |
maddin |
Feb 14 2016, 11:46 PM
Member Group: Members Posts: 168 Joined: 22-December 13 From: Australia Member No.: 16,789 Region Association: Australia and New Zealand |
ok...I thought I'd give it a go and see how sanding works.
Acetone didn't do anything on that paint anyway... I started with 180 until paint and primer were gone,then 240,400,800,1200 to get it nice and smooth. The paint hasn't bled into the plastic at all. It sure takes a while and you could get it even smoother if you put some more time into it,depending on your level of OCD. Pretty happy with the result but will try paint stripper for plastic and see how that works. Would it make sense to use clear coat to preserve it, polish,leave as is? Thank you (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-16789-1455515181.1.jpg) close up (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-16789-1455515181.2.jpg) |
Pat Garvey |
Feb 24 2016, 05:17 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
ok...I thought I'd give it a go and see how sanding works. Acetone didn't do anything on that paint anyway... I started with 180 until paint and primer were gone,then 240,400,800,1200 to get it nice and smooth. The paint hasn't bled into the plastic at all. It sure takes a while and you could get it even smoother if you put some more time into it,depending on your level of OCD. Pretty happy with the result but will try paint stripper for plastic and see how that works. Would it make sense to use clear coat to preserve it, polish,leave as is? Thank you (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-16789-1455515181.1.jpg) close up (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-16789-1455515181.2.jpg) I wouldn't clearcoat them. It yellows with time so the problem returns some day. Watch out for that acetone! It is really carcinogenic! |
Lo-Fi Version | Time is now: 11th May 2024 - 12:59 PM |
