Anyone know dimensions of RX7 oil cooler?, anyone running one?> |
Aaron Cox |
Mar 10 2005, 11:18 PM
what are the dimensions? what fittings do they come with? any pics of your install?
North Bay 914 |
Mar 10 2005, 11:25 PM
Senior Member Group: Members Posts: 509 Joined: 25-January 05 Member No.: 3,504 |
I have one I would sell. I can measure it tomorrow. It already boxed up.
Aaron Cox |
Mar 10 2005, 11:27 PM
keep me posted....
Acox914 at comcast dot net |
John |
Mar 10 2005, 11:53 PM
We used an RX-7 oil cooler once. I would recommend something new.
It was a small cooler and fit the car well. We had it located just behind the cutout on a 916 front shell. (That is about the size of it) The fittings on the RX-7 coolers are some unusual made in Japan fittings. We had steel -12 fittings (3/4") TIG welded to our cooler. When it developed a leak one day at a time trial, we determined that a NEW aluminum cooler would be better. Since then, our oil temperatures have been much lower. just my $0.02 |
Dead Air |
Mar 11 2005, 09:03 AM
Senior Member Group: Members Posts: 1,268 Joined: 9-May 04 From: Buffalo, NY Member No.: 2,042 |
My 84 rx-7 uses the oil filter fitting as the cooler.
Eric_Shea |
Mar 11 2005, 10:05 AM
23" Long
5" High I'm not sure if all the mounts are the same. I had to grind mine off to fit a GT shroud. I will be welding an aluminum plate across the top and welding aluminum studs on it to fit into the original GT shroud mounting holes. Attached image(s) |
Eric_Shea |
Mar 11 2005, 10:07 AM
Here it is in the shroud. It fits with the end that has the inlet and outlet sticking out of the shroud.
Eric_Shea |
Mar 11 2005, 10:08 AM
Picture would be nice... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Eric_Shea |
Here will be it's new home... note the GT mounted fuel pump. (thanks Rich!)
xitspd |
Mar 11 2005, 10:19 AM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
We have used several of them with good results. I used one on a highly modified 2.2 engine that I raced extensively. It was used in addition to the 914-6 cooler on the engine. We cut off the stock Mazda fittings and welded on Earls 12 AN fittings.
Martin Baker |
Mar 11 2005, 12:17 PM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
Here is the one I decided not to use. I paid $100.00 for it, I sell it for $75.00 plus shipping.
Martin Baker |
Mar 11 2005, 12:18 PM
Martin Baker |
Martin Baker |
Mar 11 2005, 12:19 PM
Martin Baker |
Mar 11 2005, 12:20 PM
Eric_Shea |
Mar 11 2005, 12:28 PM
That one's a lot different than mine. Similar dimensions though. Mine's about 1/2" longer and taller. Fittings are way different.
Lo-Fi Version | Time is now: 16th May 2024 - 03:27 AM |
