914 2.0, no crashes, maintained. drives great!, Sold |
914ltd |
Nov 19 2015, 07:55 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
This is a great driving car that most of the 40 year old maladies have been fixed. Needs paint but body excellent, needs aux oil cooler and windshield reseal. The oil temp needs to be addressed by summer. Many 1975 and 1976 914's have high oil temp. "Hell hole" solid and no previous repair, battery tray nice. It does need passenger side support for the jack tube and there is a small rust hole in longitudinal. see pix. $600. fix in my shop. The windshield reseal was deferred until paint. It can look better but it probably needs a repaint depending on your expectations. No crashes, GOOD suspension, shocks, brakes, lights, park brake, horn, excellent transaxle and clutch, nice dash, glass, interior, straight Mahle's, good (but older) tires, major maintenance service, (plugs, points, valve adjust, change all fluids, body lube oil and filters) recent Interstate battery, new fuel hoses and no oil leaks all add up to a way above average 914. I have been repairing 914's for 43 years, most of the $10,000 plus cars you'll find will need $3000. in maintenance and repairs immediately after purchase. Drive this one home and enjoy.
Sold Thanks to all. Brad Attached image(s) |
Bruce Hinds |
Nov 19 2015, 10:48 AM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Can't believe you have the jack stands on the engine mount . . . not a good idea.
DRPHIL914 |
Nov 19 2015, 11:56 AM
Can't believe you have the jack stands on the engine mount . . . not a good idea. i'm sure he knows this, but was done just to be able to take pictures of the jack points which would be hard to do if have your jack on it. - pretty nice clean car that just needs a bit of TLC and a few fixes. Love the color, good luck with the sale. - I have a friend looking and just forwarded the listing!. PW |
914ltd |
Nov 19 2015, 12:02 PM
Can't believe you have the jack stands on the engine mount . . . not a good idea. Other than the 1970 thru 1972 cars, I always use the engine mount bar to support the rear. There is nothing stronger or more secure to use. I've had a whole lot of cars up this way in the lasr 43 years. I have never had a problem. Brad |
OU8AVW |
Nov 19 2015, 03:09 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
That's a sweet car, nice value for what looks like a great driver.
rgalla9146 |
Nov 19 2015, 05:22 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Can't believe you have the jack stands on the engine mount . . . not a good idea. Other than the 1970 thru 1972 cars, I always use the engine mount bar to support the rear. There is nothing stronger or more secure to use. I've had a whole lot of cars up this way in the lasr 43 years. I have never had a problem. Brad If the bar has been bottomed and it's leaning back, fix that first. Other than that I agree with Brad. It's not a problem. |
Bruce Hinds |
Nov 19 2015, 08:39 PM
Do what you please but the cross bar was only mean to hang weight of the engine, the cross bar has a large bolt on each side, but the mount itself is only held in on each side by 4 small bolts.
It's been a long time since I've been under there, but the nuts are only 10 or 11mm and are supporting the total weight of the car(less)engine. |
mark 74 carrera |
Nov 21 2015, 07:15 AM
I'm new here ... Group: Members Posts: 0 Joined: 15-April 15 From: Austin, TX Member No.: 18,634 Region Association: Southwest Region |
Nice car and well presented.
Vysoc |
Nov 25 2015, 12:49 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
I would not argue or question Brad Mayeur, He is one of the top 914 guys in the United States.
He is a wealth of 914 knowledge. Car looks like a great value for very fair money, GLWS! Vysoc (IMG:style_emoticons/default/flag.gif) |
914ltd |
Dec 10 2015, 07:33 AM
Better than a lot of 914's that have sold for more$ Bump: a lot of grins for cheap money! |
lostreasure |
Dec 12 2015, 03:46 PM
Newbie Group: Members Posts: 44 Joined: 24-June 13 From: new jersey Member No.: 16,048 Region Association: None |
liebe |
Dec 14 2015, 05:48 PM
Newbie Group: Members Posts: 17 Joined: 10-April 12 From: Spain/Houston Member No.: 14,357 Region Association: None |
914ltd |
Dec 14 2015, 05:53 PM
Lo-Fi Version | Time is now: 17th May 2024 - 04:01 AM |
