Fuel level sending unit, Can it be tested |
Allan |
Mar 11 2005, 02:05 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Is there any way to test the fuel level sending unit before I put it back in the tank. It has alot of rust film on it and sounds like some rust flakes got in it. I have a cleaner looker unit out of a parts car but want to make sure it works.
Thanks |
jr91472 |
Mar 11 2005, 02:30 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
yes,
Consult your electric diagrams, two of the terminals on the sender will give varying resistance readings depending upon the float position in the sender. Connect your voltmeter set to ohms. If you hold the sender upright, the float should be at the bottom (i.e empty tank). If you turn it upside down, the float should to the "top" (i.e. full tank) you should see varying resistance levels in the range of 5 to 75 ohms (that was the range on my sender). Do a search here for a previous thread because it seems that different people were reporting different ranges (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I would think that the key is that you can read a fairly wide range of resistance levels. If you don't, then your float is probably stuck and you will need to take it a part and clean it. There is an article on Pelican to describes how to do this. good luck |
lapuwali |
Mar 11 2005, 04:32 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
One of the terminals is the sender, the other is for the low fuel light. Ground is the lid of the unit. Between ground and the light terminal, you should get 0-5 ohms with the float at the bottom, and infinite resistance with the float off the bottom. That's the light terminal. The other terminal and ground should show 0-10 ohms when the float is at the top (full), and 75-100 ohms when the float is at the bottom (empty).
Lo-Fi Version | Time is now: 20th May 2024 - 08:41 PM |
