Newbie Timing Question - |
David Mueller |
Mar 11 2005, 02:48 PM
Member Group: Members Posts: 79 Joined: 4-February 03 From: Calgary, Alberta Canada Member No.: 236 |
I'm trying to remove my distributor (stock unit) so I can install the fancy MSD unit I bought and I'm having some trouble finding TDC...the car is a '74 2.0L -
I have the rotor on the distributor pointing to approx 12:30 - 1:00 and I have two marks on the flywheel...when I move the wheel to rotate the rotor clockwise the flywheel rotates counter-clockwise On the flywheel the first mark I see is RED and the distributor is approx where it should be @ 1:00 - but three blades further to right on the flywheel I see another mark which is WHITE...and if I move to that one the rotor barely moves... Which mark should be TDC so I can remove the distributor ? For some reason my distributor housing doesn't have a notch in it that's supposed to be TDC..the distributor doesn't have a vaccum advance pot on it either... Second question - What would be the best advance curve to set-up for the MSD igintion - they talk about various spring weights and a advance stop bushing...any buddy have any experience setting up the MSD or even a mallory 'cause it should be similar... Any help would be appreciated... |
Mueller |
Mar 11 2005, 03:47 PM
I believe if the rotor is facing towards the plastic cap that sits on top of the fan housing, then you should be @ TDC
For the Mallory is grey/grey springs...you might be able to find a graph showing the advance curve and go from there. |
Lo-Fi Version | Time is now: 21st May 2024 - 06:02 AM |
