Rear suspension console, technical inquiry, rust repair, parts source |
mr2by4 |
Nov 22 2015, 08:38 AM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
I have a rusty lower suspension console on the passenger side. Is there any hope of finding a donor piece in good shape, or should I just get a replacement/repro piece?
It looks like the repro piece is easier to install since it is hopefully made to original spec and should fit right in. What is the best source for a reproduction console? Are they all created equally or will I be better off with one vendor over another. Is there a good video or thread to walk me through it? I found thousands of hits on the list, but have not been able to sift through them to find what I need. I had hoped I would not be doing rust repair, but ... (IMG:style_emoticons/default/welcome.png) time for (IMG:style_emoticons/default/sawzall-smiley.gif) and (IMG:style_emoticons/default/welder.gif) |
cary |
Nov 22 2015, 11:36 AM
On my replacement I drilled a couple drain holes just about where yours rusted out.
When you take these cars apart backwards you see kinds of things you can improve on. |
mr2by4 |
Nov 22 2015, 02:24 PM
On my replacement I drilled a couple drain holes just about where yours rusted out. When you take these cars apart backwards you see kinds of things you can improve on. I think that mine will be ok, since now the top is sealed and hopefully will stay that way. I would fear that the drain holes would just act as a point of entry for moisture etc. My plan looks something like this. http://www.harborfreight.com/3-8-eighth-in...tter-95343.html then http://www.restoration-design.com/store/product/PP318 I will add this to my little Lincoln Welder http://www.summitracing.com/parts/lcn-k610...CFdgDgQodXr4FwA and then I am thinking of something like this to finish it off. WARNING ADULT CONTENT So I have myself covered, but I need a bit of advice on weld through primers, seam sealer etc. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:55 PM |
