Rear suspension console, technical inquiry, rust repair, parts source |
mr2by4 |
Nov 22 2015, 08:38 AM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
I have a rusty lower suspension console on the passenger side. Is there any hope of finding a donor piece in good shape, or should I just get a replacement/repro piece?
It looks like the repro piece is easier to install since it is hopefully made to original spec and should fit right in. What is the best source for a reproduction console? Are they all created equally or will I be better off with one vendor over another. Is there a good video or thread to walk me through it? I found thousands of hits on the list, but have not been able to sift through them to find what I need. I had hoped I would not be doing rust repair, but ... (IMG:style_emoticons/default/welcome.png) time for (IMG:style_emoticons/default/sawzall-smiley.gif) and (IMG:style_emoticons/default/welder.gif) |
cary |
Nov 23 2015, 10:54 PM
So I have myself covered, but I need a bit of advice on weld through primers, seam sealer etc.
U-Pol for spray on weld thru primer. SEM, thin and runny. NAPA a bit too thick. IMO. I use NAPA because its easy. But it makes a BIG ASS mess. I'm going to try shaking it longer. On my project I've used 2-3 different brands of seam sealer. But I'm learning that I should be using a newer 2 part product. Supposedly the old school stuff will harden over time and crack and let water in, like what we see in the rear trunk area. My paint store sells Fusor brand 2 part. So that's what I'm going to switch to. |
mr2by4 |
Nov 24 2015, 07:41 AM
So I have myself covered, but I need a bit of advice on weld through primers, seam sealer etc. U-Pol for spray on weld thru primer. SEM, thin and runny. NAPA a bit too thick. IMO. I use NAPA because its easy. But it makes a BIG ASS mess. I'm going to try shaking it longer. On my project I've used 2-3 different brands of seam sealer. But I'm learning that I should be using a newer 2 part product. Supposedly the old school stuff will harden over time and crack and let water in, like what we see in the rear trunk area. My paint store sells Fusor brand 2 part. So that's what I'm going to switch to. What about the eastwood primer? |
Lo-Fi Version | Time is now: 14th May 2024 - 12:00 PM |
