Rear suspension console, technical inquiry, rust repair, parts source |
mr2by4 |
Nov 22 2015, 08:38 AM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
I have a rusty lower suspension console on the passenger side. Is there any hope of finding a donor piece in good shape, or should I just get a replacement/repro piece?
It looks like the repro piece is easier to install since it is hopefully made to original spec and should fit right in. What is the best source for a reproduction console? Are they all created equally or will I be better off with one vendor over another. Is there a good video or thread to walk me through it? I found thousands of hits on the list, but have not been able to sift through them to find what I need. I had hoped I would not be doing rust repair, but ... (IMG:style_emoticons/default/welcome.png) time for (IMG:style_emoticons/default/sawzall-smiley.gif) and (IMG:style_emoticons/default/welder.gif) |
JoeDees |
Dec 6 2015, 07:48 AM
Senior Member Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
If you want to put off the big repair, I think you'd need to get some rust killer inside that console and long before/after you patch it. You could probably drill a little hole and use the Eastwood green frame stuff.
Lo-Fi Version | Time is now: 14th May 2024 - 11:39 AM |
