Rear suspension console, technical inquiry, rust repair, parts source |
mr2by4 |
Nov 22 2015, 08:38 AM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
I have a rusty lower suspension console on the passenger side. Is there any hope of finding a donor piece in good shape, or should I just get a replacement/repro piece?
It looks like the repro piece is easier to install since it is hopefully made to original spec and should fit right in. What is the best source for a reproduction console? Are they all created equally or will I be better off with one vendor over another. Is there a good video or thread to walk me through it? I found thousands of hits on the list, but have not been able to sift through them to find what I need. I had hoped I would not be doing rust repair, but ... (IMG:style_emoticons/default/welcome.png) time for (IMG:style_emoticons/default/sawzall-smiley.gif) and (IMG:style_emoticons/default/welder.gif) |
mbseto |
Dec 7 2015, 12:07 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
The trick is to become an artist with the cut off wheel in short order. Quoted for truth. You might be able to just remove the part of the patch that is covering the console corner. Just grind that part of the weld off, and then cut the patch layer along the console edge- it should be easy to extend a scribe line from the part of the edge that is not covered. Also, if no part of that console is salvageable, I would just cut the exposed part of it out of the way, then you can pry on the remainder from the inside, so to speak. |
Lo-Fi Version | Time is now: 14th May 2024 - 01:31 PM |
