L-Jetronic Resistor pack question, Do they fail? |
RohJay |
Nov 27 2015, 07:26 AM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
The L-Jet Resistor pack appears fairly robust.
Is it a "lifetime" part or does it need replacement with time ? I am trying to collect duplicate L-Jet components to keep as back up. Just wondering if a back up Resistor Pack would be redundant. |
914Sixer |
Nov 27 2015, 08:11 AM
914 Guru Group: Members Posts: 8,873 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Yes, they do fail. Mostly due to heat. The new pack probably has different internal parts too.
JeffBowlsby |
Nov 27 2015, 08:42 AM
914 Wiring Harnesses Group: Members Posts: 8,487 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The wires frequently break off right at the resistor.
dlee6204 |
Nov 27 2015, 08:43 AM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
RohJay |
Nov 27 2015, 08:59 AM
Thanks Guys.
Appreciate your input very much :-) |
jim_hoyland |
Nov 27 2015, 11:15 AM
Get that VIN ? Group: Members Posts: 9,270 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
In 30 years of L-Jet, never had the resistor pack fail. However, I did have a wire break off. Secure the resistor pack so that it doesn't bounce around; same for the dual relay.
Having said that, I still have a spare resistor pack handy...... (IMG:style_emoticons/default/smile.gif) |
orthobiz |
Nov 27 2015, 07:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Ummm, where is the resistor pack? Pic?
Paul |
bdstone914 |
Nov 27 2015, 07:50 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
located on the passenger side by the battery. mounted to the body i have seen several wires break. I have a couple extras if you need one. New ones,are still available for about $90. i have one from an 87 Suburu with the same resistant nalues and a different plug.
Bruce |
RohJay |
Nov 28 2015, 02:34 AM
ClayPerrine |
Nov 28 2015, 04:22 PM
Life's been good to me so far..... Group: Admin Posts: 15,434 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you want to change the plug , you can get them off of any 80s 4 cylinder Nissan or Toyota. Nippondenso built the L-Jet system under license from Bosch for both Nissan and Toyota.
They are just 4 wire wound resistors, nothing fancy about them. But the wires do break and then you end up with a dead hole. |
Dave_Darling |
Nov 28 2015, 06:28 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If you get a replacement and keep it in the car, Murphy's Law will ensure that the original one never fails. If you decide to leave it out for one road trip, that's when the wires will break. Intermittently, because that's the hardest to diagnose...
--DD |
orthobiz |
Nov 28 2015, 07:30 PM
Thanks for the pics, guys!
Paul |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:52 PM |
