1976 914 INJection hesitation Need shop in NJ, Need help finding problem with hesitation |
lostreasure |
Nov 27 2015, 03:09 PM
Newbie Group: Members Posts: 44 Joined: 24-June 13 From: new jersey Member No.: 16,048 Region Association: None |
I have a great running 914 completely original but recently has a serious hesitation- Local mechanic tried but can not figure it out- Any mechanics in central NJ that are good with these Injections? thank you for your help
Amphicar770 |
Nov 27 2015, 03:37 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I have a great running 914 completely original but recently has a serious hesitation- Local mechanic tried but can not figure it out- Any mechanics in central NJ that are good with these Injections? thank you for your help You might try giving a more detailed description of the hesitation here on the forums. It is amazing how good some people are at troubleshooting over the web. You do not give details, but a common culprit is the throttle position sensor board which is on sale at 914 rubber (different versions for different engines) http://shop.914rubber.com/Porsche-914-Thro...20-91429-BF.htm Of course, could be many other things so do provide more detail |
lostreasure |
Nov 27 2015, 04:30 PM
It ran fine until two things happened- One I may have ran it out of gas? Two i added centersonsole w/gauges and possible hooked a wire wrong? My mechanic is fairly familiar w/bosche injection but has tried alot of things with no resolution- I'm thinking bad injector? It would run fine until you gave it full throttle but would buck and hesitate. Dam- any one here in NJ that would work on it- ?
JeffBowlsby |
Nov 27 2015, 05:39 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You can troubleshoot it yourself with a little effort. Game to try? Start by checking the basics. Start by checking fuel pressure incl while applying throttle.
Check the TPS board for wear. Check vacuum advance and that your advance weights are lubed and not sticking. This condition shows up a lot this time of year. |
lostreasure |
Nov 27 2015, 06:34 PM
Great- now i just need a good mechanic here in NJ that is familiar w/914 injection- I wish Brad M was close by
914dave |
Dec 1 2015, 07:28 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
I Service Imports in Cherry Hill NJ. They have the original Bosch troubleshooting equipment for Dtronic and Ltronic. The owner Fred is one of the founding members of Schattenbaum region of PCA. When I ran Dtronic he did all my troubleshooting with excellent results. Good luck.
914 Danny |
Dec 1 2015, 08:55 PM
Newbie Group: Members Posts: 3 Joined: 29-May 14 From: Mullica Hill NJ Member No.: 17,421 Region Association: None |
I have a great running 914 completely original but recently has a serious hesitation- Local mechanic tried but can not figure it out- Any mechanics in central NJ that are good with these Injections? thank you for your help Not sure where in NJ you are but I would highly recommend Powertech in Rockaway NJ. There is a mechanic/racer there Keith Peare who knows 914s inside out. He rebuilt my '73 2.0l-4 top end a few years ago. Engine has original D-jet injection and it has run great ever since and passes NJ emissions inspection every time. |
Lo-Fi Version | Time is now: 6th May 2024 - 09:52 AM |
