rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
i hate this.
k Attached image(s) ![]() |
rhodyguy |
not as much as i HATE THIS!!!!
jones |
Member ![]() ![]() Group: Members Posts: 126 Joined: 4-March 04 From: Seattle Member No.: 1,751 ![]() |
Kevin, Mine are COMPLETLY gone. When the AC lines were put in the entire sill supports were removed AND that entire front portion removed (portion close to the front wheel). I am watching this post close. I will be doing the same
rhodyguy |
when you're ready for it i'll tell you the cheap and easy way to fix the notch in the engine shelve that's cut for the ac compressor and belt.
k |
rhodyguy |
in their zeal to put in the ac, they just peaned over the edges to not chaffe the ac lines. a little pry bar and hammer action and i have semi flat edges to put the patch on. i'll mar-hyde this area, AFTER repairing.
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
K, this is the same section I'll be restoring on my car this weekend....
watsonrx13 |
Here's the other side...
rhodyguy |
a heat gun and wood chisel will peel the seam seal at the front hole fast, as in a couple of minutes. this will give you more surface area to work with. you should be able to straighten out the surrounding areas pretty easily. how's the rust inside? i cleaned it out with a pointy bendy tool to get the crud at the bottom seam out.
k |
rhodyguy |
where i live, i would deduct $500 from the price of a car that had ac installed. maybe more depending how butchered up the install was.
k |
rhodyguy |
in sort of a holding pattern. 98% of painting done. this is ready to go.
k |
rhodyguy |
oops
rhodyguy |
i hope this stuff works.
rhodyguy |
i'll finish the other fog when the parts get here. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
rhodyguy |
i'll do the rest of the pan when the rear can be put in the air. no more room.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
How is the front bearing replacement coming along?? Mine are still sitting in a box just don't have the time to work on the car now.
rhodyguy |
you mean bushings? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) piece of cake. i worried too much about how tight the races should turn on and tried a few combinations. you def know when tight becomes too tight. i have a tad more painting to do after a little welding. i could slap it together and paint later but then there's the whole overspray (black components vs silver paint) and remasking. no point in being all impatient at this time. it's not like your car is conveniently outside the door for small time projects. the whole driving to u.v. just to work on the car would get old. monique needs a 3 garage at her place out on the alley.
k |
Bleyseng |
I am working on swapping in a new rear end in the Ranger this weekend. Great fun..... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
I am sick of driving the Westy to work already....to little hp for stop and go city traffic besides being the object that EVERYONE has to pass and slam on their brakes as soon as they cut in front of me!!!!!! I need a 45 Peacemaker to shoot the assholes.... Geoff (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
rhodyguy |
you sure timed putting a new rear end in the ford perfectly. first real rain in weeks. don't let that cold wind blow up your skirt. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
k |
Bleyseng |
Yep, so this morning I shipped the heads down to HAM to get refreshed and bored out.
Looks like the rain isn't slowing down at all so perfect time to go work in the driveway.. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) I would like to thank my Boss for not letting take off an afternoon this week so I could work on it on a dry day. (IMG:http://www.914world.com/bbs2/html/emoticons/finger.gif) Geoff |
rhodyguy |
if it's the same boss i had tell hi to f-o for me, would you please? rain and 46*. perfect outdoor, car working weather.
k |
Lo-Fi Version | Time is now: 6th July 2025 - 12:44 PM |
